Motherboard problem?
TheCommander
The PC starts up with the typical boot screen- CPU speed, memory, etc... but after that it just totally goes blank. The mobo is a very old socket A board (Epox 8HKA+) but was very reliable for the time I had it. The CPU, RAM, and hard dive all work fine as I tested them on another system. It seems to me there is something wrong with the mobo.
What else do you have connected? Might be your IDE channels aren't setup properly with master/slave. Sometimes you'll get the symptoms you describe.
I don't think it's the IDE channels but I will check to make sure. This PC has worked for the past few years without any problems until now.
