this question has been bothering me, my PSU has both connectors and my mother board can use either 8pin or 4pin +12v
EATX, and EPS....what are the differances between the two, currently motherboard has plastic over other 4pins...is there any reason i should use 8pin over 4pin and take off the plastic to use it.
What is the differance between the two, I cannot find any and it probally doesn't matter which I use but I am using a core duo 2 e6400 and was wondering if there is a differance?
