motherboard POST-code analyzers?
venm11
Anyone try these things, that plug into a PCI slot (or lpt, or usb, etc) ? How useful are they in determining cause of a mobo not posting?
Yes I have.
Let me put it this way.....they work and work well BUT you have to have a PHD in "error code reading" to decipher what the card is telling you. :D
I purchased this one from Ebay and the manual is 32 pages of small printed info and error codes.
Yes I have.
Hmmm...
I noticed the one you bought, it's one of the few cards that are produced by an american company. Some people complained that their manuals are useless for the bad translation to english.
How much does the number of digits matter? Most have 2, yours has 4 some have 6. I don't know what the error codes look like.
I dunno where you got that feedback but I'll accept it as I do most.
50% of the time the purchaser doesn't have the intelligence to operate the product and at least 10% are reviewing the wrong product.
There's nothing wrong with the manual included with my unit but I wouldn't expect a non-computer savvy person to understand it.
What I can tell you is that more digits = better specific areas to look for a problem.
What I meant is that the descriptions of several *other* cards were in very bad english, unlike your card. Reviews of those cards indicated the same problem with the manuals.
I don't know how long the POST codes are; I'd have assumed that the card wouldn't simply truncate them, but rotate the numbers? (1st byte, 2nd byte, 3rd byte...).
I guess I'm lost here. My manual is fine and my findings are limited to this (my) card.
Probably/maybe but I don't know.
The more digits = longer the code that indicates the specific problem.
I have no idea how the 4 digit cards handle the situation.
I donno if you're still out there, but I got this card (or one awfully similar) and find that it does nothing on the two mobos I'm investigating. It works great on a fully working motherboard, though.
One question I have is what to do with that header cable... what does it connect to? The ATX power pins, reset switch, what?? What is this "stability" test?
Well you need the manual for your bios. The last code displayed is the problem area which you must cross reference with the manual of the mobos bios. The code will equal a component or the possible problem.
the stability test you run to see if everything is in working order after a repair. But I don't know about that card but to my common knowledge only FlipPost monitors failed Pnp signals and adapters that locks up the bus.
The "stability test" has something to do with this 2-pin wire, running from a jumper on the card to something on the mobo, but I have no idea what it should connect to
On the 2 motherboards I'm testing (dell boards made by asus), it gives no codes; just four dashes. One board gets no power (some kind of fault) and the other gets power but doesn't post; still no codes. I wonder if that since PCI is a secondary bus (HT <> PCIe <> PCI) , whether the codes are even relayed to it.
On mine the 2 pin cable is for "flexible" USB power and I see no mention of a stability test.
