Motherboard or PSU problem?
taylort232
I am getting what look like video artifacts on static pictures (desktop background, website graphics, etc), all windows video (mpgs, avi, wmv, etc on windows media player, vlc, divx player, etc etc), and any application/website with flash crashes immediately (youtube, espn, etc) despite multiple re-installations. I had this problem a few months ago, then RMA'd the video card. They sent me a new one (confirmed that with BFG) and the problem persists.
C2D e6300 @ stock - had this at 3.15ghz, it's lapped and pretty old. Orthos/prime checks out fine
2GB Corsair Dominator - memtest 86 is good overnight
Gigabyte GA-P35-DS3L rev 2 - RMA'd this because a flash bricked it. They just reflashed it and sent it back. Any chance the over-voltage I had on the north bridge could be causing this?
BFG 8800GT - brand new, so this would be two of them that produced the same result. I don't think this could be the cause
Antec earthwatts 380W - This is what I think is the problem.
Do you think this is my motherboard or power supply? Any chance it is my CPU?
[Testing the PSU]
Buy and use a digital multi-meter to monitor the voltages coming from the PSU. Follow the instructions for "Using a multi-meter to check voltages":
http://www.bfgpower.com/troubleshooting.html#DMM
[Testing the GPU]
Use Furmark or ATI Tool to stress test the GPU
[Testing the Hard drive]
Download the CD image of Hitachi Drive Fitness Test, burn the ISO file to a CD, and then boot from it, just like you would do with the XP/Vista install CD. Test the hard drive and see if any problems are found. DFT will run on most manufacturers' hard drives. Alternatively, you can use Seagate's SeaTools for DOS to test a Seagate or Maxtor drive. For a Western Digital drive, you could use Data Lifeguard Tools for DOS to test a Western Digital drive.
Sounds strange, I could only lean on the PSU being the culprit. Everything else is either new or has nothing to do with the issue...try swapping it. Just go for a descent 450-500W on www.newegg.com (preferably Antec or BFG).
- After rethinking the issue, CPU is also a possiblity. Beings that the PSU is a little cheaper and easier to replace, I would go with that first...
