Motherboard Options, Need Help
B
Bambi
Guest
Hey, first post here but I've been lurking for some time now, I need some help deciding on a new motherboard so I come begging for mercy and advice.
System Specs:
3200, 939
Connect3D ATI Radeon X800XL PCIE
1GB DDR
Here are my financally realistic choices for a motherboard, I'd like to know which one would be best for gaming.
MSI K8N Neo4 Platinum nForce4 Ultra (MB-046-MS)
MSI K8N SLi Platinum nForce4 SLi (MB-048-MS)
Asus A8N-SLi nForce4 SLi (MB-101-AS)
Asus A8N-E nForce4 Ultra (MB-088-AS)
Also, out of curiosity, this PC is being built mostly to play CS: Source, does anyone have any idea what kind of FPS I can expect to get in the final version?
I'm hesitant to buy before I know, that's how I ended up with a Celeron CPU a few months ago.
Incidentally, I don't plan on being a leech / one topic wonder, I do intend to contribute to this forum as well. :D
Since you're not going with 2xgeforce's. I'd say go with this one: MSI K8N Neo4 Platinum nForce4 Ultra (MB-046-MS), or get the dfi ultra-D
i'd go for the MSI SLI, you could always do SLI in the future, other wise go for the MSI ultra to save a little $
If you've got a system on a budget, you'll need a power supply on a budget. To me, that would rule out SLI (generally two graphics cards isn't "on a budget" either).
I love my MSI K8N Neo 4 Platinum board, it's got a ton of features and room for expansion and it's been completely reliable. I think the DFI LanParty Ultra-D is also a good choice for the right person too, if you need an onboard sound system it is a bit better than the MSI for that. I'd probably skip the ASUS; I like some ASUS boards, but I think the first two choices are better.
Thanks guys, I don't plan on using SLI and my power supply unit isn't exactly amazing right now so I'll go with the MSI Ultra.
Thanks again. ;)
The sound on the MSI SLI is the Sound Blaster. The MSI Ultra is a Realtek solution just so you know.
If you have the cash, SLI is cool. If not, the Ultra works just as well.
