Motherboard lba
R
_root
Guest
Hi!
I have some issues containing information about my motherboard.
I have a Gigabyte GA-6VX7B-4X motherboard and I have problems finding out the LBA for it.
The thing is I'm going to buy a new harddrive and wan't to make sure that my motherboard support the full size of it. I'm into buying a harddrive bigger than 200GB.
So if anybody know how I can find out the LBA or if someone know the LBA of this motherboard please respond.
Link to manufacturer
http://www.gigabyte.com.tw/Products/motherboard/Products_Spec.aspx?ProductID=1436
Thanks!
I dont know, you should just shoot a query to Gigabyte tech support. I think you might need to word your question better if I am understanding you. Your MB does support LBA adressing. The question is does the bios have whatever is needed to break the 160GB ATA 48bit addressing barrier for partition size (at least thats what I think the question really is :) )
btw I beleive the issue is partition size anyway, but check with Gigabyte. Get as big a drive as you want, and if there is a limit, its probally the 160GB 48bit ATA adressing one but you can always create a couple of logical 160GB partitions or a 160GB and a whatever is left over partition. .
This was interesting:
1) Operating System Solutions for Windows XP and 2000
The only current Windows operating systems that natively support the full capacity of ATA drives
larger than 137GB are:
Windows XP Home Service Pack 1 (SP1) or higher
Windows XP Professional SP1 or higher
Windows 2000 Professional SP3 or higher
Windows 2000 Server SP3 or higher
The original Windows XP (RTM or Release to Manufacturing) and previous Windows 2000
Service Packs do not support ATA interface disc drives larger than 137GB
