motherboard decision
kevinf
sorry i have another decision that i have to make. i am choosing between the A8N-Sli premium and the A8N-E. i am not doing sli but i just like how there are so much features in the A8N-SLI premium, i also need to know if these two boards support PCI video cards (not express). i don't have a pci-e right now so thats my only choice. i also have the xclio 450 Watts so the board need to be compatible with it. remember i am not doing SLI.
the asus should work with a pci videocard--my older a8n-sli deluxe will work fine with one.
as for the 450w-psu -- if it has enough amps on the 12v-- it should be OK --think about 20a on the 12v rail as a minimum. a antec 450sl will work fine--even with a opwer hog-6800gt/x850xt
as long as it is not SLI. the 450antec sl--can do sli if their 6600gt's though.. :cool:
Maybe best thing would be to find an onboard solution with a PCI express slot. You might enjoy it a bit longer than an SLI setup with no PCI-Express cards. The MSI RS480M2-IL Socket 939 ATI Radeon XPRESS 200 Micro ATX AMD Motherboard has integrated graphics and PCI-Express.
If you're heck bent on SLI, then go with the Asus board, and drop in an extra $50 and get a pci-express 6200TC.
In any case, you will get better performance on an ATI integrated set or a 6200TC than any pci card i can think of.
in the past i had micro atx boards and i hated it, the upgrade options were limited because of the pci slots. this is the power supply that i have will this work with the a8n-sli premium, and if i was to get 2 6600gts then would it work
My only suggestion is don't get 2 6600GT's :). I had them for a while, and it was neat to run SLI, but I don't know if it's worth it.
ya i know i just wanted to know if the power supply can take it, and right now i just want to choose between those two, i am leaning toward the sli premium because of the features but my most important question is that if the motherboard will take pci video card.
