Motherboard decision blues
RobertM
:( I have been reading and checking the forums and stores for all the components I want for my first build. It's been quite a learning curve because I really am new to all this...just starting out. I've decided on a QX6700, 8800GTX (1 for now, SLI later), Corsair 9136 memory X2, 4 Gig, Western digital and Seagate drives, Enermax 1000 W power, and all the rest that a system needs, put into Kandalf case...probably not the LCS watercooled case.
What's holding me back is the Motherboard. I would like to buy as close to the latest offerings as I can, but I am full of trepidation at the thought of having to deal with all the problems which seem to be inherent in the 680i chipset...Striker, ABIT IN9 32X Max, Asus P5N32-E SLI, BFG nForce 680i SLI etc etc.
I can't believe that so many boards are on the market with so many issues. True, some seem to have good luck either getting a board that's not a lemon, or are able, through experience, to correct issues through settings etc, but I don't have that experience or expertise. After laying out @ $6000.00 (without monitor), I would like a system that works...really well!!!
Is buying a highend 680i really a crap-shoot? Are they all crap?
Now I'm leaning towards something like Asus P5WDG2 WS Pro for the stability it offers. However, I'm concerned that I'll be wanting to replace the board sooner than I might need to if I had purchased a 680i board.
I see that some of the 680i manufacturers have offered recent bios updates/patches, but I am not really seeing a decline in the number of posts by frustrated builders complaining of one issue or another. For instance, BFG released their Bios version P25 for their 680i board. Has this improved it very much, or are there 6 more patches needed? Is the Striker still a major headache or have updates made it a viable/sensible option?
I sense the various manufacturers are hell-bent after the highest $$ and are rushing product out the door without adequate product development. I know this happens in every industry, but...I see very few builders who are happy with their 680i systems...tweak tweak tweak crash!! If 680i's were cars, most wouldn't make it off the lot before breaking down.:rolleyes: :(
I really need some help with this...instability is something I don't have the experience to deal with, and even if I did....I don't have the time! What should I buy?
Thanks!!
Robert
No suggestions? The 680i roundup at Thoms Hardware is an interesting read. There aren't any answers it seems concerning the 680i, at least until the manufacturers put their half-baked products back in the oven. The recent bios upgrades I've seen have contributed only minor fixes...I wonder if the next generation will soon render the 680i obsolete before it's even off the ground.
http://www.tomshardware.com/2007/02/22/680i_motherboard_comparison_part_2/
Robert if you are a good pc builder and you can find ya way into the bios easily then the i680 is a good choice when you want SLI, Intel boards do not support SLI only Xfire unless you want to use modded drivers wich might not work with every game. Bios 25 for the EVGA, BFG boards are good, 1002 for Striker and 0902 for P5N32E are good stable releases too...
For the memory I would wait a bit more some I680 boards are having issues with 4 gigs and overclocks. Settle for 2 gigs in the meantime and see how the dust settles. Also don't pay to much cash for memory modules, I know Corsair is highly recommended but at this moment I can get my OCZ 8500 kit (5-5-5-15 @1066mhz) for around 320 euro's about 380 dollars here. Also note that a Core2 duo CPU isn't that heavily reliant on memory timings as eg an AMD CPU is. I wouldn't waiste so much money on the ram alone. PLZ check the rams with the QVL list of the mobomaker !!!
Also the CPU is a bit overkill go for the Q6600 instead this can also achieve easily 3200mhz and saves ya loads of cash to get eg a decent watercooling setup. These quadcores run very very hot and the stock intel cooler is barely enough so invest directly in a decent heatsink for the CPU. Also the difference between a Q67 and Q66 isn't noticeable unless you benchmark your rig....or do proffessional 3d encoding or movies generating stuff....
Case wise I have a Thermaltake armor similar to your Kandalf , if you really want this model pls buy the alu silver model with the fan in the sidepanel !, This steel one is a heavy motha (black case). Otherwise I can recommend Coolermaster Stacker for future watercooling gear or amasing aircooling and yet silent....PLZ don't buy an LCS model as it will underperform with ya current hardware setup ... modding ya existing case will be far better than the poor watercooling setups thermaltake sells...
Also for the Enermax get the latest DDX edition which has far better 12 volt rails ( think 24 amps instead of 17 ) then the normal galaxy and costs about the samea and is more futureproof,
All by all you can save loads of cash get similar performance and you can get ya 2nd gfx card for free instead of wasting it all on those expensive ram modules or extreme CPU. Buy ya girlie or wife some nice cloathes go on a holiday....
Just my thoughts....
Leeg,
Thanks very much for your reply...you've made some excellent suggestions!!
I have no experience building and so know nothing about Bios settings etc, but I would like to learn. I will be using some 3D programs/editors, and doing a lot of heavy Photoshop work, which is why I had settled on the 6700, and the capability for SLI also has appeal. The 680i seems to offer the most...but not if it's constantly crashing.
I realize that this "cutting edge technology" will have some rough edges, but when I read that seasoned mod builders are fuming over the difficulties they've experienced wwith the 680i, I start to believe I need to looka t other options.
Again, because I don't have any experience, I look at what seems to be the best on the market and hope I can afford it....that's why I have been considering Corsair modules. I'll look into your suggestion about memory for sure.
The case...yes, it was the silver model with the fan that I had decided on, and perhaps the Thermaltake Symphony Mini after awhile if necessary. I am concerned about liquid-cooling systems that may eventually leak etc.
It's been suggested that I pick up the Scythe Ninja Plus rather than one of the Zalman fans...still researching that.
My wife likes your suggestion about clothes and a holiday.:)
Thanks for your input...appreciated!! I'll be giving all this some serious thought and will watch to see if there's any more news about bios improvements etc.
Well with my suggestions Robert you can save about 700 - 1000 dollars and you won't feel the difference, it's amasingly fast and quad core at the moment is so overkill unless you are a 3d modeller or movie encoder....
On a note plz don't buy Thermaltake watercooling components, they are inferior in performance then eg Danger Den, Swiftech,... and cost about as much, maybe slightly easier to install but performance will be very poor in comparison...and not even worth the cash... once you get it installed you will buy dangerDen or Swiftech in the long run...
Leeg,
I will be involved in 3D modelling as well as mapping with some of the gaming editors and so the 6700 seems like it would be my best choice.
I have been following all the information in this forum about the EVGA 680i (122-CK-NF68-AR) board and it looks like a solid choice if it's not pushed too much. I am also still interested in the Striker if the instability issues have been rectified. You mentioned the 1002 Bios update for the Striker. Is this a stable borad now if left at default settings?
I'll be going with what seems best in about two weeks and I'm hoping more updates on some of these boards will surface.
I'll check out the watercooling companies you've mentioned...appreciated!!!
Thanks again for your help!!! It's a little daunting for a noob to wade through all the info and feel comfortable making decisions about what to build with.
well mine is even rock stable at 9 x 400 with my E6600 just back from a LAN , rig didn't budge. Very impressed with it. Even with earlier biosses at stock all was fine, just we needed to get full control again over the CPU voltages, with 1002 this is a fact.
But like the EVGA it has bios options galore once you want to tweak it. Be a patient man , ask around and get a good overclock out of it... think best Bios for EVGA will be 24/25 one...
Overall the newer biosses are getting most issues out of the way now, the future looks good :)
I think your real problem is going to be whether or not the 680i issues are all sorted out with respect to quad core CPU's. Personally, I wouldn't buy that combo (but then again, I would be looking to OC it and that's half of the problem).
I was just reading all the angst on the EVGA site about the problems so many are having, even with the newest Bios 25. So, there's no way I can feel comfortable buying an EVGA 680i board at this time
Too many issues...too much lost time, unless tweaking and problem solving technical issues is what one likes to do.
:confused: :( :confused:
I hope I can find a 680i board that's rock solid stable at default and perhaps with some light OC capabilities. Too much to ask?
*** Suggestions will be greatly appreciated.
Asus P5WDG2 WS Pro (975)
Asus P5W64 WS Pro
Asus P5B WIFI-AP (965)
Intel D975XBX2KR BadAxe (975)
Asus Striker Extreme (680i)
Gigabyte GA-680i SLi DQ6
ABIT IN9 32-MAX WI-FI
BFG- nForce 680i
EVGA 680i 122-CK-NF68 -AR or BR (so-called replacement board)
nVidia Reference 680i ECS PN2 SLI2+
DELL :
BTW, I save almost $2000.00 building their flagship, using better components in many areas.
I'd take a good hard look at SLI. If you drop that, you can go 975X and the Bad Axe 2 which is a great board. I'd take that over any SLI board right now. I'm sure at some point Nvidia will get their act together, but right now 975X is the best option (unless you need SLI).
At this point I would wait to build until May when Bearlake is coming out. It will have ICH9 or ICH10 with 1333 fsb nad support DDR 2 &/or 3. C2D is reported as gaining 15% better performance and there are things like hardware firewall, PCIx 2.0 etc. Maybe newer boards will be more stable. It's a flaky time now because you have hoards of people leaving AMD and moving to a new Intel architecture and manufacturing at the same time as VISTA is getting into market. A lot of things seem half baked and staffs are overworked. Intel rushed it's chips out when AMD picked up more Dell buisness and board makers seemed half assed (Newly released P5WDH's board didn't boot with retail C2D's because Asus had only tested with engineering samples - I mean come on!?). I wouldn't go near those Nvidia chips now. Between their boards and their vid card drivers thats one maxed out crew at the mo.
I don't entirely understand what people see in SLI/Crossfire etc Why pay 2x for less than 2x performance along with all the extra headaches? I think makers took "enthusiasts" on a ride with that one. Now I just read ATI's RD600 will suck up 2-3 hundred watts. How is anyone going to stick 2 cards like that in a computer (to play Oblivion lol)? Between the RAIDs, the SLI's, the over-souped up ram and overpowered psu's I think the enthusiast market is being goosed to want stuff that is is more heat than light. SATA 2.0 is mostly a charade and the PCIx 2.0 is the next carrot on the stick (I still Bearlake for other reason though)
Like abcdelight said, waiting for the Bearlake board may be an option. However, after waiting for the release, which is even longer if you want one which supports PCI-e 2.0, you then have to wait until a descent BIOS is released and teething problems have been cleared up like with the 680i chipset.
Robert, my suggestion for you now is to wait until all the glitches and problems are fixed on a hardware level. I read somewhere that the EVGA's 680i is being fixed with a little modication to the board to correct the problem people are having now. If you wait, I would say within the next three months or so, there would be new revision boards out that you then buy and build your PC without all the headaches right now. My decision for myself, I'm gonna wait until all the dust settles and the sky is clear before taking a plunge. I will let other people have the headaches while I wait. Much, much headache this way.
well he can wait for 8950GTX too, , in PC bussiness you can wait forever, when buying cutting edge technology when it's hot you can run into trouble, but believe me most 680i issues are solved, I ran my Striker board for 3 days on a LAN at 3600mhz 24 hours leeching, playing, upping, no data corruption , no lockups,...
Just pick ya components carefully. Also does Bearlake support Nvidia SLI ?, no idea 680i does support 1333FSB CPU's, do the pencil mod and you will see the mobo will recognise a 1333FSB CPU even if it's your trust worthy E6600...
And like always then it's DDR3 , then it's PCI2.0 do they all give the phenomenal boots the marketing boys want us to believe, remember wow AGP 8X that should be twice as fast as AGP 4X didn't notice a thing, PCI express amasing speed increase yeah think if you compare an AGP 6800GT with a PCI express version performance was up to par. In the long run yeah , but after a few years some components have already been swapped to deliver better performance...
And don't forget many issues reported are mainly due to poor setup or components choice, but also due to inadequate knowledge of how to build and tweak a pc...take eg one guy fried a dimm on his EVGA board, and suddley all over the wsorld everybody fries there dimms, EVGA confirmed it were isolated cases, to bad for the ones that had this issue but if you read on forums the 680i overvolted the dimms then you wouldn't setup ya ram with 2.3 when in fact it gave 2.4... Test it lauch some mumbo jumbo and you will half a dozen followers , some don't even own the board lol or knwo how to get into the bios...
Kirby,
I listed the 975X boards because I do realize that there is a great deal more stability there and lots of performance too. I missed listing the P5W DH Delux, which was CPU Magazines 1st choice for the Intel mobo, January 2007. I am confused about the 975 boards...which one is best now?
I appreciate you suggestion very much, and am giving it lots of thought. Thanks!!!!
abcDelight,
Yes, there seems to be some definate flake in this high-end market, and, being new to it all, I'm really surprised frankly. I don't know about Bearlake but will search for info. It may be possible to wait, but build times now (3D editors) on my current rig are too long which means I may not have a choice...I may have to build soon.
I really don't want to fall into the trap of getting maxed out high-end gear that isn't needed or that doesn't add considerable performance. It is importantant to not get taken in by all the hype.
Thanks!!!
Mansize,
Waiting for the bugs to be ironed out of new product is never fun...I agree. That just adds to the time it takes to get settled with gear and into the workflow that is necessary. I'm afraid if I wait 'till May I'll then hear it's been postponed until August etc etc....appreciated!!
JC,
I will most likely be following your advice for at least the next while. It seems that nVidia and others are really trying to get the issues fixed, although there are quite a few users really unhappy with EVGA's latest update. As mentioned by ABC, a lot of difficulties are likely occurring by trying to marry up components that are somewhat incompatible, or through inexperience. Yes, there is a lot of dust to settle, and I would like to avoid all that.
Thanks!!
Leeg,
That is a problem...the waiting. I really don't want always the "latest/greatest", but do believe I should go as high-end now as possible. I'm intrigued about your success with the Striker. I would buy one today if I could have your stability. So many that went for the Striker are frustrated with all the issues, and yet, like yourself, there are many who love the board. Those with issues may very well have brought on all the problems through inexperience, poor component matching, crazy bios settings ...or all of the above.
Keeping in mind that I trully am totally new to building, I hesitate to go for the suped up Striker.
Guys...thanks so much for all the replies. I will continue to watch the forums, and check the manufacturers. If something comes up that you think would be important for my decisions as a noob builder, it would be great to hear from you.
* This is a serious forum I can see, and I'm pleased to have your input/help!!:D
Robert
Kirby,
Right now, I'd say
1. Intel Bad Axe 2
2. Asus P5W DH Deluxe
Other than those two, I wouldn't really get a different 975X board. Maybe the DFI or MSI if you're on a budget, but the Bad Axe 2 can be had around $180 or so if you shop around. I'd pay $20 more to get that over one of the others.
