Hey guys
Here's the rundown:
Gaming (battlefield 2 & soon 3, MMoRPG's), office applications, light photoshop
600 (less is better)
3) Where do you live?
Belgium
4) What exact parts do you need for that budget? CPU, RAM, case, etc.
explained below
option 1: motherboard, CPU, VGA
option 2: CPU & VGA
5) If reusing any parts, what parts will you be reusing?
Corsair HX620W psu
Gigabyte MA970XT-UD4P motherboard (again see below)
2x2GB 1333MHZ kingston valueram
Coolermaster 212+
6) Will you be overclocking?
Yes
24" 1920x1200 BenQ V2400W
Between september and december (if my graphics card won't break, i'll keep it till december)
9) What features do you need in a motherboard?
Firewire, USB 3.0, SATA 6Gb/s eSATA
10) Do you already have a legit and reusable/transferable OS key/license?
Yes, 32bit windows 7 but It is possible for me to use the 64bit version via a microsoft license pack from the company I work for.
Now, about my situation:
I currently have an phenom II x3 720BE, I overclocked it to 3.2ghz but it fails in prime95 after 1hour. Steady at 3.1ghz though but I'm afraid this will not be enough for Battlefield 3.
Also, my current graphics card is making really strange sounds (XFX 4870 1gb XXX) and the heat has become a concern (76°c idle). I have cleaned the graphics card and changed the thermal paste, but nothing seems to work.
Question: If my graphics card would quit on me, should I go for and Intel sandy bridge config or get an phenom II X4 processor andsave money on the motherboard in stead?
Also, I want a high end graphics card (cost can be around 300), but ofcourse I don't want a CPU that bottlenecks it.
Here's the rundown:
Belgium
explained below
option 2: CPU & VGA
Corsair HX620W psu
Coolermaster 212+
Yes
