Motherboard / CPU / Memory recommendation for MathCAD
johngalt47
I need the fastest Motherboard/CPU/Memory combination to use with MathCAD. The emphasis needs to be on which combination allows the fastest floating point calculations.
Secondarily, it takes forever for the program to load into memory.
Graphics speed is not that big of a deal.
I would be willing to spend $2,000 on the motherboard / CPU / Memory.
It has to run Windows XP.
Since your budget is more than sufficient my strategy is to recommend a very high performance system at stock speeds with the capability for a huge increase in performance if modest Over Clocking (OCing) is an option. However OCing should/would not reduce stability or reliability of the system. In this context OCing means tuning the system for superior performance. In order to achieve that goal several pre-conditions need to be met. The computer case must have good airflow, 120mm fans front and rear. This does not imply an expensive case, in fact something like this is sufficient. Nor does this imply many noisy fans, the larger fans move much more air at lower speeds providing the best compromise between quiet operation and air movement. By all standards EXCEPT function and cooling, it is a piece of junk, I use them all the time ;) If my computer was in my living room I would choose something else. But to just sit on or under a desk and do its job well, it has few peers.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147074
A high quality power supply, not necessarily high powered, but high quality. However I am going to recommend a quad core processor so we will need something with some "omph" to it if for nothing else but wish to run it well below its ratings to ensure low noise, long life and reliability. I just bought one of these, and I am very impressed. It has more than enough power in all regards unless you stick in some monster power hungry video card (do not, the mid priced 8800GT just released is more that sufficient if you decide you want to play a game, or need some graphics intensive capability, otherwise an inexpensive less than $50 card will do. This supply will easily cope with either scenario ) This supply is very quiet.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139004
There is a 750W version as well but that is overkill unless the video or other items not mentioned would place large additional loads on the supply.
OK to the meat of it, remember you said "the fastest" so that is my criteria without compromising the system goals outlined above or using esoteric hardware difficult to procure.
MOTHERBOARD
I do not believe the newest X38 Intel chip-set boards are stable enough to consider nor, at this time offer a clear cut performance advantage over the more mature (but still new) P35 chip-set boards. Based on the Floating Point benchmark results in different reviews around the the web I recommend
http://www.newegg.com/Product/Product.aspx?Item=N82E16813127030
The board will support the upcoming Intel 45nm CPUs with a much larger on die memory cache, something that could make quite a difference with Mathcad, I just do not know for sure and cannot find out. This board easily supports 4 x 1GB sticks of memory at high overclocks. Its little brother the IP35-E would also serve.
MEMORY
As fast as possible seems to be the ticket. Using memory multipliers to run the memory as fast as possible would seem a clear path to improved performance in large complex calculations but I am guessing a lot as I cannot find details of Mathcad's sensitivity to things like CPU cache, memory sizing or speed, etc.. Therefore as the budget is sufficient I err on the "overkill" side. Windows XP does not "read" or fully utilize 4 GB of ram but it is not totally wasted and RAM is so cheap ATM it is silly not to fill the machine up. If you do go Vista later you are set, and meanwhile you give Windows all the ram it can use to prevent things like silly disk swaps while you are calculating the dynamics of the fusion reaction at the suns core.
Memory: (procure 2 kits for total of 4 GB memory)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145043
CPU
I considered Xenon etc, however they now are just Core 2 processors repackaged. A look at floating point synthetic benchmarks show Intel is the leader in Floating Point calculations and the performance scales exactly with CPU clock speed. This makes sense as all current Intel processors are the same chip with only minor difference s in the amount of cache. Also with high quality system components it is basically child's play to set up the system so that a medium speed Intel processor meets or exceeds the performance of the top of the line processor running at stock. There is just no justification for a super expensive processor and the one below is a quad core so if you wanted to do other things while Mathcad was chewing on a problem you easily could. This also sets you up for future needs and basically for the measly $279 there is nothing else even close for the performance/price. In 10 minutes you can have it running at 3.2GHz and exceeding the performance of the $1000 version of the same chip. Cache size is the same as the $1000 chip, it IS the $1000 chip just with a locked multiplier that will not hinder you at all in overclocking.
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115017
CPU cooling, do not install the stock cooler but instead replace it with a high performance one that is quiet but more effective. Avoiding massive enthusiast heat-sinks but something that will enhance reliability and stability if the decision to overclock the chip is undertaken. Care was taken to select a downward blowing cooler that in addition to cooling the CPU provides "blow by" air movement to cool the CPU voltage supply circuitry around the CPU socket due to the possible heavy current load of the quad core processor. Quiet. Fan can be easily replaced with a high performance unit if desired.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835185042
Note that I did not include every little detail, case cooling fan, keyboard etc..
Note that some mechanical acuity is required to assemble the components.
Disclaimer: The components were selected with care on their merit as to the specified task and are all widely used in the combination described above. However I can take no responsibility for component compatibility or suitability for any particular function.
