Motherboard/CPU Compatibilty & Bios
tuffgong
I have a question. Do certain motherboards not support newer CPUs until the BIOS is upgraded? I ask because I just bought a Gigabyte Socket 754 motherboard and newer Venice 3200+ CPU and it wasn't in the original CPU compatibility chart.
Would I need to sub in an older CPU to boot up and upgrade the BIOS first?
You shouldn't have to. The CPU chart was probably made right when the motherboard debuted and is outdated.
Good chance that it will work. The worst thing that could possibly happen would be that it wouldn't boot. OK, the very very very worst thing would be a voltage change (fire), but the BIOS should recognize the CPU fine.
Which motherboard is it? Or at least, which chipset?
~Ibrahim~
If it isnt on the chart, i would guess that it WONT work.....unless you do a bios upgrade....my experience is it usually will say it will work with this bios or later. It would be a good idea IMO to have a cpu that does work with it handy just incase.
The motherboard is a GA-K8N51GMF-RH and the CPU is a Socket 754 3200+ Venice 2.2ghz.
Uh, doesn't it say in the supported list:
AMD Athlon 64 3200+(E6,Venice,90nm,512KB) 1600 F7
~Ibrahim~
CPU Supported List
F7 is the bios that you need in order to support it? If you're buying new, you should be fine, and if you're not buying new, just use the old CPU to flash to F7 or later.
I did buy new...and it does say supported, but I don't know which BIOS my motherboard has. As for buying new...yes it's new, but how long has it been on the shelf would be the better question.
The socket s754 Venice CPU's have been out for a while now. Unless the board is over a year old, I'd expect it would support it without a problem. If the box says "Sempron ready" or something like that, you should be fine since most of the semprons for s754 sold today are 90nm like the Venice.
If it is new, it should include the latest BIOS (F7), which means it is compatible.
~Ibrahim~
I own a GA-K8N51GMF-RH, with a 754 AMD64 3200+ on it, you have to adjust the settings in the bios for the cpu, mine is a mobile.
makes a great Vista MCE machine
