I'm looking into a new motherboard along with a new cpu and Ram
CPU - http://www.newegg.com/Product/Product.aspx?Item=N82E16819115055
RAM - http://www.newegg.com/Product/Product.aspx?Item=N82E16820220353
(If you have any suggestions on these two things also, please let me know)
I'm stuck between a few motherboards, what do you think?
Gigabyte 89.99AR - http://www.newegg.com/Product/Product.aspx?Item=N82E16813128345
Gigabyte 104.99AR - http://www.newegg.com/Product/Product.aspx?Item=N82E16813128359
Asus 81.99AR - http://www.newegg.com/Product/Product.aspx?Item=N82E16813131347
(I'm leaning toward this one, as it is the cheapest and my budget is definitely tight, however, I've read about a hot northbridge. I looked into aftermarket chipset coolers, and I'm not sure whether one would fit with an 8800 in the pcie slot. Anyone know for sure?)
