Motherboard choice - video editing
Going to build a rig with the main intent to be video editing, needs lots of horsepower and memory so I7 and 12 gigs of memory, windows 7, have not built a pc in a while and am a bit confused about these new baords. No gaming will be done, stabilty is the main concern and speed is very important. So, which motherboard board would you pick? I may overclock but again stability is most important will use big case and good cooling.
Thanks,
Mike
Have you considered a Mac with Final Cut Pro?
For the PC side, have you considered using a hardware add-on card, like the Matrox RT.X2?
Just curious, but what kind of video will you be editing, ie, SD, HDV, AVCHD, long format, short format?
Will you be using After Effects a lot (this would be the reason for lots of speed and lots of Ram)
Will you be outputting to BluRay?
I did consider a Mac and even a Hackintosh set up. I already have CS4 for windows and Sony Vegas, so I would rater not buy them again. I will be doing AVCHD and blu ray. Building a high power PC may allow the Hackintosh solution if windows does not work out.
thanks,
Mike
Well speed wise, they're gonna be close to the same since they're based on the same chipsets. Stability wise, the Asus P6T SE and Asus P6T are very stable motherboards that can OC pretty well. Also take a look at eVGA's X58 motherboards.
