courtney01
- Nov 25, 2008
I was trying to install my intel stock HSF, and the push pins were really difficult to get in. The first push was fine, it clicked as it was supposed to. But then the rest of the pins were increasingly difficult to push in, and the last one was especially impossible. I had to put a lot of force into it, and most of them except the first one didn't even click. I only realized they were locked in place when I looked underneath the board and the pins were through. And I'm not even sure it's completely locked, because for the last pin I pushed, the male and female pins have a gap between them, even though I can't push them together any more. I had to put it on and take it off couple times, and while I was twisting the pins in order to detach the HSF, I would hear creaking/friction/metal spring sounds. Is all this very bad?
And how much can a motherboard bend before it's bad? The board was bending a bit when I was pushing down on the pins really hard, but I didn't hear anything crack. I inspected the board from the side, and it's slightly curved in the middle now, but I don't know if that's how it originally came or if I did that. Are motherboards usually perfectly flat/straight or are there occasional curvatures that aren't a problem?
