Motherboard Audio Connection
sitalchauhan
Hi, I have got quite an old motherboard and just bought an Antec P180 case. I have got everything working apart from the front audio connections on the case as I cannot find which connections go to which pin on the connection on my motherboard. The front pannel audio connection on my motherboard is the green socket in the follwoing picture:
Please could somebody tell me what each pin is for in the connection? (ie mic, etc)
Thanks
That looks proprietary or something. An old OEM board? Most front panel connectors have different pin outs for speakers/mic. Maybe 9 pins now? Looks like a USB header.
What you have a picture of is the line-in or Aux inputs for your onboard sound.
Sorry, but the picture I showed above was not actually of my motherboard, but has the exact same connection. Here is an actual picture of my motherboard
I am 100% certain that it is an audio connection because it was used in my previous case for the mic port on the front of the case. My previous case had the exact green plug that goes straight in, but the p180 has lots of single connections so I need to find the pinout of the connection to see which goes to what pin.
As you can see in the pic, it is labelled as JAudio, not TAD as in the pic I found on the internet, sorry :(. The large white socket next to it is for the case front USB connections (Labelled USB1.1 on the motherboard).
As the motherboard is OEM, I do not have a manual. It is called the MSI MS-6399 (also says Medion 3000 Ver 1 on it), but it is really uncommon and cant find any info about it. I even emailed MSI and they said that there was no manual made for it because it was made just for OEM for Medion.
I am really stuck.
Does anybody know if anything bad can happen if I just plug the pins in and do it by trial and error and see when it works?
That port is the analog Line-in. It's not going to work with the pin out front panel connectors on newer cases. Best case scenario is that you could isolate just the mic parts of the pins on the P180 and plug those in and not have the headphone jack work.
As for the individual wires, they are all the same on every motherboard. Just look at one of the newer motherboard manuals and the pin-out should be the same.
Now I just need to find the pinouts for the Analogue Line-in connection and I can connect each wire to the correct pin. I only want the mic port to work on the front of the case, dont really care about the headphones.
I have checked pinouts.ru but couldnt find it...
Does anybody know what the pinouts are for the analogue line in connection??
And does anybody know if I can do any damage by doing trial and error on the pins until it works?
Thanks
The pinout on the analog connection is (from left to right)
Right channel
Ground
Ground
Left Channel
The individual pins on the front panel connector of your case should be labeled. Find the two mic ones and one of the ground connections and give it a try.
