mother board question
Crazy tech
I just got a new epox 8kda mother board to replace my schizophrenic msi k8n neo platinum board (I think the bios is screwy after the 1.9 flash, then back to 1.7)
My question is would I have to reinstall windows? Or would windows just work since both are nforce 3 mother boards?
I would reinstall. I have heard that you can "reseal" windows so it rerecognizes all of the hardware, no sure tho. If you just swap and boot you will have glitches methinks.
I think you should be ok since the hardware changes aren't too significant. Good luck with that board. It worked well for me.
