vanilla_guerilla said:most of those silly tower things.
most underrated - xp90/xp90 cu
if you check sites that review and rank hs/f (overclockers.com for example) this cooler is rated higher than the xp120, si120, and the tower things at a lower price, and less chance of them ripping out of your mainboard if they get shifted suddenly. its been around a while, but so have raptors, lian li cases, the who's "live at leeds", '66 corvette, etc
ER34 said:XP90 pwnz the AMD stock heatsink... oh yeah...
http://www.madshrimps.be/?action=getarticle&articID=399
kirbyrj said:Too bad most budget AMD chips don't come with that HSF. I'd like to see more reviews other than the one madshrimps one on the AMD stock HSF. Also, the tests done were with both using the same AMD fan where you can always put a different 92mm one on the XP-90 rather than the 80mm AMD fan.
that's a good one!Asian Dub Foundation said:Asetek Microchill
roaf85 said:Vantec Aeroflow
Have one cooling my Xp2200 Rev A0. Stock temps were 60/67 C load and installing the Aeroflow dropped them to about 52/58 C. However what I got in return were ridculous case vibrations, and undervolting only makes them worse.
revenant said:does it have to be a current cooler? if not, I vote, the chrome orb!
Ockie said:XP-90 was way overrated, people swore by them and it was the end all solution.... now they have moved onto the sythe and say the xp90 is junk.
I figured it might but I wanted to try it. XP-90 sucks to install and uninstall. I also think the place I bought the heatsink from on ebay is sending me a second one on accident.Retsam said:Thats what I swapped my xp-90 with. Now my stock amd heatpipe sink cools identical to the xp-90 heh. And is actually quieter. Easier to install as well.
Eihli said:Well I'm just saying theres much better heatsinks on the market, such as the Alpha I got which dropped a 55/72 prescott down to a 26/33. Unless your case has good air flow a heatsink w/o a fan such as the scythe just doesn't live up the hype. I have a micro-atx so my case has horrible air flow, so that might be the main contributing factor as to why I think its pure shit...
so you think the ninja is pure shit b/c you dont like the fact that it can run fanless? hav you ever used one?Eihli said:Well I'm just saying theres much better heatsinks on the market, such as the Alpha I got which dropped a 55/72 prescott down to a 26/33. Unless your case has good air flow a heatsink w/o a fan such as the scythe just doesn't live up the hype. I have a micro-atx so my case has horrible air flow, so that might be the main contributing factor as to why I think its pure shit...
MatDef said:Yeah, thanks for the alert. Too bad I already bought one, and it only lowered temps 10c (idle/load). I guess I should return it.
