Black Morty Rackham
- Jan 8, 2004
On my PC, iTunes doesn't use more than 20 megs of memory and usually so little CPU power it doesn't even register in the Task Manager. It does use a tad more CPU power on the iBook, because it's so much slower, but it's not too bad.That was in reference to your "Feature Crippling" comment. Though I would tend to agree that 100+MB is overkill for an MP3 player. I never said I don't like iTunes, I simply don't like the memory and CPU power it takes up to execute such simple tasks. I like Apple's software (hell, I own a Mac, that has to count for something) I just don't feel that I should have to sacrifice an eigth of my system memory to listen to a song.
Well, my point is that iDVD is not a part of Mac OS X, and is thusly not relevant to the discussion if it's a bloated OS or not. And iLife is not bloated because it uses a lot of hard drive space. Both iDVD and Garageband use a reasonable amount of space, considering what they do. The pre-made loops and themes is basically the whole point of the applications, so using a couple of megabytes of hard drive space isn't really an option for them.The same can be said about any software, which would make this entire thread sort of a moot point...
