The Inquirer said:This time, the problem is plain and simple incompatibility, we have reports of 8800s not working in several PCIe 8x slots
ryan_975 said:Well there's the problem. They're trying to fit an 16x card into an 8x slot![]()
Arcygenical said:Bah, Inq.
Who here's got an 8800?
Now, how many of those don't work in your motherboard?
/thread
yevaud said:Raises hand.![]()
The 8800 series will not work in the Pci-e slot (16x dimension) of the Asrock 775 dual vsta motherboard. I guess this is why. Not Pci sig passable. So much for a bios fix solving this.![]()
Arcygenical said:Not really... It's because of all the technical issues behind allowing so many features on such a budget board. It's a VIA chipset, one that doesn't perfectly reproduce PCIe, as a cost from the AGP ability.
It's VIA's fault really, not due to the card.
This doesn't count because the mboard vendor states that the 8800 series cards will not work with the board.yevaud said:Raises hand.![]()
Kliter said:...
Since it's obvious theINQ hates nVidia (for whatever petty reasons), I'm thinking they won't stop here trying to spread their bias.
And I guess that ATI advertisement has more meaning to it than I thought.![]()
MrWizard6600 said:exactly right. its not spicifically Nvidia, its the G80. They have been ragging on it since day 1. In almost every one of their articals on the G80 they sum up everything good in one (poorly written) paragraph and then expand on all the downsides, in five others. To top that off they always mention this in comparison with their (wrong) numbers about AMDs R600.
The Inq gives pure speculation, which has upsides and downsides. It means you can get some information way ahead of when it's supposed to be released, but that the majority of the time, the information is wrong.
To the resistor problem: a lack of 1Ω will simply overvolt a few transistors. Very very little damage would be done, and functionality should be fine.
and to the 16X vs 8X arguement. Theres two aspects to a pci-e slot. what it mechanically (as in its physical dimentions) is, and what it electrically (as in how much bandwidth) is. It is entirly possible to run any card that requires 16X on a board with a mechanical 16X slot but electrically supporting 8 lanes. Remember, First versions of SLI split the 16 lanes going to one slot into two 8x groups, and sent them to each slot, and as Nvidia has stated several times, the 8800 will support SLI on any motherboard which also supports SLI. You will see a very minimal performance sacrifice by going from an electrical 16X mechanical 16X slot to a electrically 8X slot Mechanically 16X slot. An example of a mechanical 16X slot electrical 8x slot is on the 680i motherboard, the middle graphics card slot actually supports a maximum of 8 lanes.
yevaud said:And seanmcd, please post a link to where ASRock states that the 8800 will not work with their mobo anywhere but in email correspondance.
I'm not quite sure why an email from ASROCK themselves to YOU is not enough. That's what I was basing that statement on. Your previous thread. Did you make that email up?yevaud said:seanmcd, please post a link to where ASRock states that the 8800 will not work with their mobo anywhere but in email correspondance.
seanmcd said:I'm not quite sure why an email from ASROCK themselves to YOU is not enough. That's what I was basing that statement on. Your previous thread. Did you make that email up?
http://www.hardforum.com/showthread.php?t=1130608
Zinn said:who cares if it's not "pci certified?" there are plenty of usb compatible products that aren't "usb certified." if it works on chipsets and motherboards that aren't completely retarded, (such as not VIA chipsets) then I don't see what the big deal is.
