Monitoring HD Temps?
ZzBloopzZ
Is there a way to find out the HD temps on HD's that are connected through a PCI Controller card? I've tried a couple programs that check the temp via SMART... but they can't even detect the HD's on the PCI Controller's. But the HD's on the onboard controller on the mobo are detected. I guess because it thinks the HD's on the PCI Controllers are SCSI?
All of the HD's are WD 8MB's. I'm using a HighPoint RocketRAID100, Promise Ultra100 TX2 and a SIIG ATA 133.
its likely they dont support temperature monitoring at all
my WD400BBs dont, I think the Raptors do? but I also think they are the exception
temperature monitoring done through a controller card is generally done through array management software,
for instance my Promise Array Management suite (PAM Utility w\ a SX6000)
which will give me rudimentary SMART info (as well a array control, status, error logs, alerts, email alerts ect)
SCSI drives had temperature monitoring long before IDE drives
The PCI Controller cards i have have no monitoring software. :sigh:
I guess i'll have to qucikly throw them on the onboard and boot up and see temps? :(
EnderW said:
I can monitor both my drives through MBM5 using SMART
But are they connected to a PCI controller card? I can monitor my drives too, but they're connected to the onboard IDE headers.
ZzBloopzZ said:
Just read the help file included with MBM 5, it will walk you through it. Only works if your drives have SMART monitering.
Nope, mine are connected directly to the motherboard.
If you are really worried about your HD temps you could just stick your finger in on top of the hard drive (the metal side) and see how warm they are. They should be cool to moderately warm, and if they're really hot you should add a fan near them or something comparable.
