Monitor not getting signal
eternaljammer
Everthing seems to power up properly but nothing on the screen.I have done everything short or removing everything and reinstalling it all back together and reseating the cpu. I gave up but once I get some more time I will try that but its a pain removing and reinstalling my ultra 120. :mad: Anyone have any input? Its not the video card.
Test everything else in other computers to eliminate possiblities. Clear CMOS, double check everything, reseat everything. Make sure no standoffs are touching the backside of the motherboard. If you recently removed the motherboard or static shocked it without knowing, you probably killed it in some way or another.
I doubt your CPU needs to be reseated or your board is dead.
I would guess one of your other components isn't seated properly or powered properly. I get issues like that when my PSU isn't strong enough or when I don't attach one of the power connectors.
Do you know if it is even POST?? Any beep code? When the computer is on and running, keep pressing the Num Lock key. Pay attention to the green LED on your keyboard (make sure your keyboard isnt usb), does it flash on and off? If it does, then the computer is on....are you using SLI?? If you are, you need to hook it up to the top video card in the left position looking from the back. Check the dvi adapter if you are using it, check the monitor on another computer, try hooking it up w/ vga if applicable. Let us know a little bit more information to better help you.
I have tried monitor on a different comp. Monitor works. I will rebuild the comp and see if it helps. Someone said same thing happened to them and they rebuilt it on a antistatic bag and all worked again. I hope that works.Will keep you posted. Off to work.
I had a computer I looked at that wouldn't post at all or it would but would loose video signal right after. Went through every part in the system and couldn't find a problem until I removed the heatsink and fan off the CPU. There was far too much silver paste on it, causing parts on the top of the chip to short together. I also noticed a small piece of dust between two of the pins. After cleaning it up and putting it together correctly everything worked great.
dont rebuild it on an anti-stat bag. i dont want to start another debate on this, but the outside of an anti-stat bag is not necessarily a non-conductor. use a piece of wood or cardboard.
I'd start by clearing the cmos. I've had that problem before when I push the fsb too hard.
You could also pull everything that is not required to boot.
an Ultra V Series 500 WATT psu. :( Alright I reseated the cpu and made sure processor was clean of any dust. Still nada.
I am planning on buying a new psu maybe this thing just can't handle my set up.
E6300, DS3, 1GB GEIL 5300, 6800GT w/ silencer. 2 Delta 120mm fans, fan controller, 1 Plextor dvdrw and hd.and a 120 mm thermaltake case fan. Plus leds on my Tsunami dream case. What do you think? :confused:
