Hello Guys,
I have a small office (fewer than 10 employees) and I wish to monitor what my employees do. So I want a router which can log traffic and block sites. Can you suggest how to go about it or which router I can buy for that ?
I think a router can keep a very small log as its memory is limited. Can new routers keep log for a week or so ? If not, what should I do ?
Is there additional ways of monitoring employee's systems ? Though I am not keen on installing anything on their systems but if there is no option then can you recommend a good software for that.
Thank you,
Cheers,
GR
Thank you,
Cheers,
GR
