Monitor Modding
Burn23
So, I was thinking about modding my monitor to match my case... really just removing the outer shell and giving it a paint job, and maybe some other stuff once i get the shell off. Any place out there that could help me out and show me anything that i might need to know before jumping right into this.. :) 'Cuz it looks like my monitor only has a few screws that hold the shell to the face.... maybe more once i get it open though.
Ruckus
Hardforum Moderator-in-Chief
Staff member
I dont know of any moitor tutorials, but I've alweays liked the monitor mods. i.e. windows in the side and color matching. I cant stress enough though DO NOT TOUCH THE CAPACITOR IN THE MONITOR. It can kill shoot you across the room and stop your heart.
JMasterFunk
Let monitor sit off and unplugged for a few days...
a few days later press the power button on and off just to make sure it's as discharged as you can get it...
Remove back of Monitor... set aside...
If you REALLY want.. take a screwdriver or preferably a resistor and discharge the capacitors that look scary to you.
try not to put your fingers under the suction cup...
remove four screws attaching tube to front.... remove other screws that are holding in the PC board, etc....
CAREFULLY set tube aside... take the board with it.
you now should have all the plastic peices separate...
spray with vinyl die or whatever you're doing.. cut holes, change LEDs from ugly to another color.....
let dry...
put monitor back together.... and don't fuck it up.
profit....
That's how I did it...
oh yeah.. and i'm not responsible if you do something horribly wrong....
Ruckus
Staff member
let dry...
profit....
LOL you better remember to ground the screwdriver or you get a nice suprise, because you become the ground.
eL c0L0mb1aNo
Originally posted by Vertigo Acid
www.twistedmods.com has a tutorial for monitor mods
That was the best I've seen. YOu might also want to try www.bit-tech.net I think i saw a tutorial there. Look in the articles section. Don't kill yourself though. The only really dangerous part of the monitor is under the little suction cup dealy. The rest won't necessarily kill you but you might want to stay away from it if you are really scared. :)
’m‚³‚ñ
I know someone who was almost killed by a capacitor in a disposable camera.
emorphien
I know someone who got tossed across the room by one too.
’m‚³‚ñ
Did he have second degree burns on his hands/skin? The guy I know that did that had severe burns on his fingers and one of his thumbs.
DRxAndy
ive painted two monitors
take your time taking it apart
be very cautious
and you'll be fine
oh also
krylon fusion is awesome :D
eL c0L0mb1aNo
Meh. Me and my dad have played around with many monitors, televisions, VCRs, etc. As long as you unplug them and turn it on and off a few times to get rid of whatever charge is in there you should be fine. Just keep your hands away from them if you really are that worried about them. Also depends on what parts you touch. But to be safe follow what everyone else has been saying.
’m‚³‚ñ
Just curious... Would a grounding strap help at all? I mean, wouldn't most of the electricity go through the grounding strap into the third prong of your 3 prong outlet?
I've taken apart many a powersupply. Good way to get free fans. :p Dead power supplies, that is. Some of them still worked, though.
Whatsisname
uh sure they have plenty of power but they dont have enough to toss someone across the room.
emorphien
right. :rolleyes: When your body convulses from one of those things (if it doesn't kill you) you'll probably launch yourself in some direction.
cgrant26
All you have to do to de-energize the flyback transformer and CRT is pull the plug while the monitor is on. I still wouldn't touch anything that looks ominous though. I tried to a disassembly with pictures for a tutorial but the old ass monitor I picked was probably the worst example I could have found and most of the pics were crappy. I'll have to give it another go when I take apart my main monitor for cleaning next time.
One important thing to remember is to tape off or remove any moving parts as not to adversly affect their operation. (I.E. adjustment knobs, access doors, power buttons, Etc.) Also don't forget to spray the paint from all 4 sides so you don't discover any unpainted spots when you put it back together. Those vent grills can be a real bitch to fully coat. For really nice paint finishes, you can warm up your oven and place parts in it to dry. This will help give the paint a nice glaze. Just make sure you turn it off before putting plastic parts in there because the local heat from powered heat coils can warp or melt the plastic.
Vertigo Acid
2(-log[H+])4u
I actually ROFL'ed when I read this... If you wear a grounding strap, you are going to die!!!! The key to staying alive when working around high voltage/amperage electricity is to *NOT* be a ground. Hence, that's why people that work on power poles and the like wear rubber shoes and are isolated from the ground. If you are completely and totally 100% ungrounded and have no clear path to ground from your body ( Dunno how you'd acchieve this), you could touch all the caps and flybacks you wanted to, and then you would be at the same potential as it. Then, you could shoot electricity out of your body to a grounded object, say you neighbour. However, you'd die because you completed the circuit through you. Kinda OT, but fun to think about anyway.
Burn23
Awesome, thanks for the good links!!:)
hehe, yeh, maybe ill stand in a puddle while i do this! :D
Whatsisname
you hit two poles of the same cap you will fry, whether you are grounded to the 'outside' or not.
’m‚³‚ñ
I don't know. I've heard stories about people being grounded and getting way more than enough voltage/amperage to kill someone and they only felt a little buzz. Not sure of the exact circumstances though.
Sc0rched
Using a grounding strap is not the smartest idea when dealing with monitors. You can read that anywhere... Its different with PCs, but when you are dealing with monitors and power supplies the capacitors in them are carrying an electrical charge which you dont wanna mess with, while PCs dont.
File
Speaking of horrible death by electricity, has anyone actually been killed by a monitor before?
Whatsisname
whether you or grounded or not has very little effect on whether caps are going to fry you or not.
randyc
Best Person
this reminds me when I was little, like 8 or nine years old I pulled apart an old monitor and had no idea of the risks.
(I lived through it btw)
’m‚³‚ñ
Not that I know of. Although, I might die from a monitor sooner or later (I used to work in a small, enclosed space at school with a pile of monitors. One would fall off and start hissing, or someone would kick one over and it would hiss. Lots of broken tubes...)
cgrant26
Absolutely. The Best Buy service center I worked at had 2 TV/Monitor related deaths alone in the past 10 years. I don't know what the figures are nation wide, but I bet it's a lot.
Compuwiz
You cannot be killed by a capacitor in a camera that has a 1.5V AA battery in it....moron.
It sings, might hurt a little, and it will leave some scar marks on your skin....but its not enough to kill you. If ya wanna have some fun with it though, cross the two wires on the capacitor and see what happens. :D
Ruckus
Staff member
Yes i knew an older guy in his late 40's early 50's that his heart stopped after being shocked from a monitor capacitor.
emorphien
Shows what you know. "moron" grow up a little.
Vertigo Acid
2(-log[H+])4u
Don't really want to make this turn into a flame thread, but i've got some experience w/ bioelectrics. I'm involved in Athletic Medicine at my school extracirricularly, and work with E-Stim (Eletrical Stimulation) machines daily. The amount of electricy required to kill you if discharged across or through the heart is in the 2-digit milliamps, ie 10-20mA. The voltage doesn't really matter death wise(more likely to get shocked w/ a high potential tho).
So, yes, if you took for example a capacitor out of a camera, hook a sharp probe up to either side, and shoved one on each side of you circulatory system, with a path through you heart, you probably will die.
fenton06
has anyone evertriedmolding an LCDflat panel into the side of a case? I think thats what I'm goingto do with my next case.
’m‚³‚ñ
That is true. My mother is an RN, so I have seen a few documents showing how this happens.
However, Cameras don't just take 1.5v, they store up electricity in their capacitor(s). They actually can store 230 volts and up. Don't believe me? Well, then, open up a disposable camera yourself and find out. How else would my aquantience get second degree burns on his hand?
emorphien
Those capacitors store a large amount of energy to give the flash enough power to fire. Granted the caps in a disposable are small, but they're still quite dangerous.
If I had a disposable to take apart I'd tell you what cap it has in it.
Whatsisname
doesnt matter that the battery is 1.5v. The camera has circuitry that feeds the caps upwards of 300volts. If you are an unlucky fellow, that can stop your heart.
MasiveMunkey
I've taken apart a disposable camera and was shocked by it, but it didn't seem that big to me and it definitly didn't damage me in any way. How can you resist not taking them apart... it's so much fun.:)
emorphien
You got lucky, there must not have been much stored in the capacitor when you got to it.
