I need some monitor, that is fast enought to play games wihtout distorting textures or object edges (most notable on grass or trees) and is able to display black image without distortion (color/contrast tints like white glow with IPS)
I've got some older Samsung TN monitor - TN is absolutely out of discussion - pure black screen in dark room is min. 1/4 ruined with silver/bronze tint.
Than I bought Dell 2711 - IPS - this is awesome monitor. It's fast enought (no ghosting even in pixperan), beautifull colors (I like wide gamut with oversaturated colors in non managed applications) and excelent viewing angles. Antiglare filter is bad, but not realy a problem. Reason I'm looking elsewhere is IPS white glow, which absolutely destroy black/dark images altought with straight view (altought looking directly to the center of the monitor, edges are under some viewing angle and there is very notable white glow).
So I bought VA panel - NEC EX231Wp. Picture was perfect. Black was so good, that I can barely see where the screen ends in completly dark room. I was really amazed and I do not notice any "black crush". Superb - until the picture moves. I known, that this monitor do not have any RTC but I thought that it will not matter. But unfortunately it's almost as bad as 10 years old monitors. Games are absolutely unplayable and text is almost completly lost when moving window. Very very bluring with every movement.
So I changed this super monitor for Samsung S24A650D which have panel with same contrast (3000:1) but with RTC. Unfortunately 2 things happend - panel is notable worse than nec (nec have samsung's pva and samsung have mva from other manufacture). Black was not so good (but definitely better than on dell 2711), there was some slight bleeding on edges but worst was the "black crush". On black screen there is "blacker" spot in the place where are you looking. So when you move your head, this spot is moving along. And more - even with RTC, this monitor is still very slow. Games are now playable, but textures is till notable blury while moving and when you play some games with stars (eg. solar 2), all stars are gone when the sky is moving.
soooooo... is there ANY good solution for playing games with not ruined dark scenes?
i'v got also plasma tv - its what i want. Picture is awesome, black is black and response time is unmeasurable. But smallest one is something about 40" and there is image retention )-:
I known that OLED will solve everything, but when it will be byuabe? 2015? What till then?
I'm now considering 3 things:
1. is there some IPS panel with not so notable white glow? (I know that it's technology problem, but then again - VA NEC monitor has almost no "black crush" while same VA technology in Samsung monitor has very notable "black crush")
2. is there som VA panel wich is speed enought to not blur everything?
3. I like new 120hz TN panels - for games 120fps will be great improvement (and i have good GPU for 120fps). But - are these new TN panel as bad as old ones? I do not want to look from angles - but my old TN has even with the straight look huge tint on black images.
thanks for any advice...
