Monitor choices.... Limited
Defense
I got a monitor at BestBuy awhile back. It crapped out. Sent it in with my warranty and they want to replace it with something "comparable" in store. Here's what I got:
Gateway 24" 2485w
* S-PVA -- 1920 x 1200 resolution panel (16:10 Aspect Ratio)
* 500 cd/m² brightness
* 1000:1 contrast ratio
* 6ms pixel response
* 176° viewing angle
* DVI with HDCP (Supports 480i,480p, 720p, 1080i)
* Two component (Supports 480i,480p, 720p, 1080i), composite, S-Video, and VGA inputs
* Picture-in-Picture
* Faroudja DCDi
Here is all BestBuy has:
Dell STB2410? 24"
http://www.bestbuy.com/site/Dell+-+24%22+Widescreen+Flat-Panel+LCD+Monitor+-+Black/9808484.p?id=1218176553066&skuId=9808484
Asus VE245H 24"
http://www.bestbuy.com/site/Asus+-+24%22+Widescreen+Flat-Panel+TFT-LCD+Monitor+-+Black/9704656.p?id=1218154377047&skuId=9704656
Or this LCD tv if I want to keep PiP and components:
Sony Bravia 32"
http://www.bestbuy.com/site/Sony+-+BRAVIA+32%22+Class+/+1080p+/+120Hz+/+LCD+HDTV/9761147.p?id=1218168617254&skuId=9761147
All I do is game game game. I want the very best monitor for gaming. Which monitor should I get? Or should I insist they fix my monitor? I don't care that the lcd tv is worth more.
Thanks
if the sony TV can do 1:1 pixel mapping over your preferred input and you have the space to sit back a bit from the monitor, for gaming it seems like a better "bang for the buck"
