Monitor Bezel Modifying for EyeFinity
xjmtx
with Eyefinity showing up all over the place in these forums the biggest complaint isn't squished views or too tall views, it's the bezel adding black bars to the gameplay.
My proposal, lets mod the monitors' bezels to make our displays appear seamless.
My problem, what is the safest way to go about doing this without ruining the LCD?
How to make a frame for multiple displays to remove "black bar bezel" syndrome or BBBS.
these guys have gotten it figured out:
http://www.seamlessdisplay.com/products_radius320.htm
is it better to use metal to secure the lcds close together to create the illusion of seamless? do you need to keep the monitors' innards from touching? help me cure BBBS. together we can make a difference.
Insulate them? The actual panel would be held in place by a metal frame. If that links up to the mounts on the back, then you're set!
