HardOCP News
[H] News
- Dec 31, 1969
This is definitely one of those "I totally wasn't expecting that" videos. Good thing that camera caught all the action at 5000 frames per second or you would have blinked and missed it.
I was expecting that, sodium explodes upon contact with water. That idiot should have at least googled the chemical he was fucking with.
Probably. Gotta remember that water flashing off into steam expands at a ratio of 1:1700. Do that fast enough and since the surrounding water isn't compressible... you would get a kaboom.Salt is not volatile to water, What I'm wondering if at that temperature, the sodium separates from the chlorine, or is it just so damn hot that the water vaporises rapidly?
It's just the steam.Salt is not volatile to water, What I'm wondering if at that temperature, the sodium separates from the chlorine, or is it just so damn hot that the water vaporises rapidly?
I wonder what would happen in a swimming pool?
I definitely have no idea but was kind of expecting it due to H's headline. However, my first thoughts afterwards other than holy shit is like yours. This idiot could have been seriously hurt or died as a result from the injuries. The projectile glasses could have seriously f''d him up, like ripped up his front chest and stomach area.I was expecting that, sodium explodes upon contact with water. That idiot should have at least googled the chemical he was fucking with.
Exactly. The explosion was from the super-heated water trying to expand in that little, glass aquarium and it had nowhere to go but through the glass. They would have had better results using a 1/4 thick polymer cubed contatiner that could have withstood the pleasure of the expanding water.
Still fun to watch.
But I think the result everyone wants to see IS the kaboom. Fun to watch indeed. I was surprised it took so little to create such an explosion.
Entertaining video, but making glass explode over a lawn is just a really bad idea, especially if kids / pets ever venture out into the yard. At a minimum this should have been done over a concrete surface and with a much longer pole or a remote-controlled robot.
This was my first thought too. I'd end up sodding over the whole yard if I exploded this much glass on it.
My second thought was anyone playing with explosions while wearing shorts and a loose shirt is a dumb ass.
Perhaps it the surface area of the salt increases when it interacts with the water, because it is an ionic compound and the water is also ionic.
Still fun to watch.
All the elements in column 1 are highly reactive in a similar manner with water....they just get much more exatic and harder to handle and expensive as you go. If you take pure sodium metal and expose it to water, it is quite violent.
I don't know if you saw the "why sodium explodes" video in this thread higher up, but in one of the tests they drop sodium (or maybe it was potassium, not sure) quickly deep into water and it explodes very quickly. The point at which it explodes there is little air to oxygenate the hydrogen near the sodium and not enough to create such an energetic explosion. Furthermore, after the explosoin is finished, the hydrogen THEN ignites and you can see it burn off afterwards. Alkali metal-water explosions doesn't seem to be caused by hydrogen burning.Sodium is, yes. Sodium chloride is not. Sodium chloride melts quite happily and doesn't somehow become elemental sodium.
Elemental sodium reacts with water to form hydrogen, sodium hydroxide, and lots of heat. The heat flash-boils the water, and creates a high enough temperature for the hydrogen to ignite with the O2 in the air. That combination is why you get a nice explosion with fire and smoke when you throw a hunk of sodium into a pond.
I'm not sure why you think it's a stream explosion. What's your evidence? I have seen many videos of people pouring/putting/igninting substances in water that are at far higher temperatures than molten salt, they do not explode. They boil violently and sink to the bottom. Look up videos of molten aluminum, molten copper, even lava pouring into water.That's not what's happening in the video, though. This is a pure steam explosion from the heat. No chemical reactions going on as far as I can tell. Something seems to have discolored the melted sodium chloride though, so there's probably some contaminant.
Sodium is reactive to water, just very mild. Try the old salt-water trick with a connection and a lightbulb trick.
Now, when you apply a crap ton of stored energy into a reactive substance like Sodium, which is normally mild in nature, you get the exact opposite effect. Look at potassium, tons of stored energy in its inert state, when put into water it explodes, same thing happens with Sodium when you give it tons of energy. What you see happening in the video is sudden expansion of energy when the salt comes into contact with the water.
When the salt is poured into the water, the water starts absorbing the energy until the expansion is too fast for the water to absorb and its released in the destructive force.
If you could instantly boil water, the steam would go for the least resistive path and just steam straight up o. It may super heat the glass enough for it to become brittle, but that's besides the point.
I dont understand whether you are agreeing or disagreeing with me on the reason alkali metals explode when exposed to fire, but that's ok. I'm more curious why you think this is a steam explosion.Depends on the video. In some videos there's very rapidly some fire and smoke. I expect it depends on how quickly it sinks beneath the surface before the reaction occurs. If it's still covered in oil, you'll probably not see fire until later if at all. If it's fairly dry, and can react immediately upon hitting the water, you might get the fire.
What makes you think this would be anything other than a steam explosion? He didn't pour sodium into water, he poured molten salt into it. Really hot objects in water will create steam, the expansion rate of water into steam is 1:1700. If any water became steam and expanded, it would push against the water surrounding it which cannot compress, hence... kaboom.I dont understand whether you are agreeing or disagreeing with me on the reason alkali metals explode when exposed to fire, but that's ok. I'm more curious why you think this is a steam explosion.
