I've been wanting an external storage solution for awhile. After plenty of research, I plan on going with an external SAS solution. I do not want a rack-based solution and am therefore going to build a mini-tower storage unit. This build will be for a future WHS home network (streaming, encoding/decoding and back-up). SAS is new to me, so I have several questions.
System Goals
Make a small, quiet, fairly energy efficient "modular" server unit with hot-swappable external storage. It will have to do HD encoding/decoding and streaming.
Case/Enclosure
I have extensively searched for a basic external enclosure for hard drive use (ideally, 8-bays). I do not want to use a typical mini CPU tower, as it is not compact enough. I found plenty of ready-made systems, such as this somewhat reasonably priced one from PC-PitStop, to this slick, pricey one from iStoreagePro. I know I could build one cheaper. However, up until earlier today, I couldn't find a single suitable case. I finally came across this today: Addonics (would get the bare-bones Tower IX and likely replace the PS). Does anyone have any experience with Addonics cases? Also, please let me know of any other similar case solutions you are aware of (again, compact, non-rack mountable). I have a feeling whatever case I end up with, I will probably be swapping out the fans for quieter ones.
SAS Expansion - Hard Drive Enclosure
At this point, I have no need to have this enclosure ready for SAS expansion (in terms of daisy-chaining another case). Regardless, the only way I am aware of making this work is with the Intel SAS expander or the HP SAS expander (and would need the appropriate power solution for the HP adapter, as the PS cannot simply plug into it, like the Intel unit).
It definitely seems SAS storage solutions for the home are a fairly niche market. The storage unit I plan to build (if using the 9-bay case above) will give me up to 27TB. Even maxing it out -- and even setting up either the Intel or HP expanders for future expansion via daisy-chaining -- I would have unused SAS ports on the expander. As such, I am wondering if there are expanders with fewer ports (therefore, likely cheaper) out there? For my solution, it would need to work like the Intel and HP, only needing to have power supplied to it (no need for data from an internal motherboard).
SAS Controller - Server Side
I would probably be comfortable just using pseudo hardware RAID. As such, I am looking for a fairly cheap 6GB HBA SAS host controller. All I truly need is 1 external mini-SAS 6GB port (or only 1 internal and use an adapter for external connectivity). The closest I found to this is the LSI 9211 (with the addition of an external adapter). I am definitely looking for more card suggestions, or even input on this particular card.
Hard Drive Bays
What are some recommended hot-swappable hard drive bays? I have little knowledge regarding the requirements of these bays for an SAS set-up (are there differences?). I will be using SATA drives, most likely WD Caviar Greens.
Server - Case
I am not exactly sure how I am going to build my server at this point. However, it will be small and may end up being a bit overkill. I say overkill, as I at least do not plan on an Atom based server, or something similar. As I mentioned, it will have to do some HD decoding/encoding and streaming. I am leaning towards the server being a Phenom II x4 build (pretty cheap. . .and may underclock and undervolt (and possibly even just turn a core turned off, if need be). We shall see. . .
Either way, I have been looking into small cases for the server. The server itself will just have the MB (w/ CPU and memory, of course), one HD, the SAS controller card, the PSU, a network card and a Blu-ray drive. I saw a couple Lian-Li cases I liked, but I would probably just use those for an HTPC build.
So, I am also looking for suggestions for a small mini-ATX (maybe even ATX) case. Obviously, with external storage, I do not need (and do not want) a big case. I want something small, quiet, not totally fugly and not rack mountable. I'm not too worried about this, as one shouldn't be too hard to find.
Thank you,
Paul
System Goals
Case/Enclosure
Hard Drive Bays
Server - Case
Thank you,
Paul
