Modular or Not?
Rustynuts
I've always adhered to non-modular is better as it takes one potentially iffy connection out of the mix. Each non-soldered connection will give an itsy bit more resistance and reduced current flow, right? Does anyone care about this anymore? Was shopping for a Corsair PSU and noticed on their high end units (Pro Gold) they ONLY have modular cords. Some lower end units have both as a choice. WTH?
No one really cares about as it's not that much of an issue anymore unless that person is really OCD or anal about it.
Well modular cables are often seen as a "premium" item so of course high-end premium PSUs would have modular cables to further add to their value or marketability.
Modular makes for a neat inside computer space, thus better air flow.
However, I have an older modular PSU that I no longer (if ever) have the cables for. And I can't order new ones for it. That sucks.
No. It's completely negligible.
I am buying my first modular power supply today, mostly because I am tired of a rats nest of wires, I had a custom built psu with the longest goddamned wires for the last 5 years and I am fed up.
I am nervous about the connections, every short I have ever had from a psu was the result of a short in a molex connector, seems like it adds more risk by adding more connection points.
i have a corsair modular power supply and still working fine ever since the q6600 first came out.
I don't like the thought of losing cables. My rig is in a full tower Antec Twelve Hundred and there is plenty of room behind the motherboard and underneath my hard drives to neatly tuck cables. I didn't do a "rate my cables" type of job, but with all fans on low speed (except for the H50, those are on medium) my temps are WELL within spec.
You could probablly make your own. Afaict the connectors on most modular PSUs are standard molex "mini-fit" connectors so it should be pretty easy to get them. You would probablly have to use a multimeter to figure out the pinouts as afaict there is no standard for that.
I would say your case's cable management is an important factor in this decision.
Buying a non-modular PSU today is like buying a CRT monitor today.
Yes, the non-modular PSU, much like a CRT monitor, has several advantages over modular power supplies. But these are negligible compared to the disadvantages, and in general, non-modular PSUs are pretty outdated and should be reserved for budget builds.
I could see having the 24 pin soldered on, maybe the cpu 4+4, everybody needs those
everything else? modular please, rocking the ax1200 here...love it
