Hi!
I've been peeking on the forum for months now, reading threads on S1, S4, A4, Sentry and many other great, community based projects. In fact I've been working on a project on my own, and I finally got the courage to present it to you. I'd really appreciate an honest feedback. Due to the case being mainly 3D printed new features are incredibly easy to introduce. Each opinion could result in real changes to the project.
www.modivio.com
xCase is a line of console-style computer cases perfect for your next gaming PC, workstation or an elegant PC for your living room. All versions support standard and widely available mini ITX motherboards. Furthermore there are versions supporting full length graphics cards and SFX power supplies.
The main component of xCase is a 3D printed bezel. Bezel contains mounting points for all main components and ensures structural integrity of the case. It's manufactured using high-strength ABS material. Side panels are laser cut from acrylic glass.
Improving the airflow is one of the goals of the project. Hole pattern on side panels of xCase allows you to mount 80mm and 120mm fans directly on them. Furthermore xCase S, M and L support up to four 60x60x10mm fans while xCase SE, ME and LE support up to four 80x80x10mm fans mounted to the bezel.
FX_Project
Congratulations. I think you have done a nice job so nice that I want to get in touch with you and help to bring this xCase to life! Hope to hear from you soon. Have a nice day
Thanks! Sounds great, please send me an email at contact@modivio.com .
BTW. I have a version compatible with a new Noctua L12S in the works!
D
Deleted member 222586
Guest
Hi,
It looks rather good, IMO though I suggest that since you have different variations of the case you make a comparison of the 3 (with pictures) so as to see the differences graphically. Also, you should talk about your target price point.
rfarmer
Hi,
Take a look at his website, you can find all that info there. Xcase.
I just updated the first post of the thread. If someone feels like some more info is lacking just let me know, I'll gladly answer all the questions. Up to this point I wasn't very active because there wasn't much interest here. I'd love to change that.
Thanks! I made a render showing different versions of the case. Furthermore possible builts and compatible hardware can be found under those links:
www.modivio.com/xcase-s
www.modivio.com/xcase-se
www.modivio.com/xcase-m
www.modivio.com/xcase-me
www.modivio.com/xcase-l
www.modivio.com/xcase-le
