This is my third PC build. My last build, a mini-ITX build didn't go so well, so I've since learned to ask for help. I ended up with a few extra parts that I want to put to use before they're out of date.
Mainly gaming. Some web browsing and programming. The most demanding game that I want to play is The Witcher 2. However I don't really care if I have to turn settings down and I don't have a high res monitor. I just want games to run smoothly at native res + reasonable settings.
Under $500, Tax + shipping not included. Cheaper is better, but I don't want crappy parts that will die on me.
3) Where do you live?
Boston, MA, USA
CPU, GPU, PSU, motherboard, case
Corsair H50
Kingston 2x4GB 1066 DDR3
Intel 320 Series 40GB SSD
WD Caviar Green 2TB
Scythe Slipstream 120mm case fan
6) Will you be overclocking?
Probably not.
20" 1280x1024 Gateway monitor that I got for free. The power supply was broken so I replaced the capacitors and it runs well.
End of this month or early next month (July).
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
I'm more concerned about quality parts. wifi would be a plus but is absolutely not required, so long as there are a few usb headers or a PCIe x1 slot. I want to get an mATX form factor with four RAM slots. If the deal is great I'm not averse to going full ATX.
I have a license for Windows 7 Ultimate 64bit/32bit.
Here is what I've picked out. I want a quiet, small system, but more importantly I want the system to run cool with reasonable upgrade options.
Case: COOLER MASTER Elite 360 RC-360-KKN1-GP $39.99
GPU: MSI R6850 Cyclone PE Radeon HD 6850 1GB $169.99 - $20 MIR
CPU: Phenom x4 965 BE +
Mobo: Gigabyte GA-880GM-UD2H mATX $159.98 - $15 MIR
PSU: Antec BP550 Plus 550W Modular $64.99 - $15 MIR
Total Cost (sans shipping+tax): $434.95 - $50 MIR
The CPU and mobo come in a bundle from microcenter. I've seen better deals from them, but is this a good deal? Everyone praises Gigabyte boards, and it is definitely a step up from my shitty zotac board.
My current GPU sounds like a jet turbine when it starts up so I went for something with good reviews and a large heatsink. Would it be cheaper to buy one without the heatsink and purchase the heatsink separately?
Thanks for any input
Boston, MA, USA
Corsair H50
WD Caviar Green 2TB
Probably not.
