Shakezilla
- Aug 15, 2004
So my vid card was overheating like no tomorrow, so I went to bestbuy(had a giftcard) and bought a dynex 120mm fan, went to put it in my case and realized that the mesh part on the side wasnt ment for a 120mm fan its like a little bit smaller square, so I put two screws in the fan and put it there anyways but like 1/3rd of the fan is just sucking the side of the case and its loud as hell.
So could I cut away the mesh part of the case and make the whole bigger and install the fan and use modders mesh to cover the fan hole?
Heres my main questions, where should I buy it? Nothing fancy just black and cheap
The mesh goes on the inside of the panel correct?
And when I cut it what is the best tool to use to cut the side panel of the case?
Heres a pic of the case: http://www.newegg.com/Product/ShowI...+Chassis+ATX+Mid+Tower+Computer+Case+-+Retail I installed the 120mm fan in the bottom mesh like section, it might be hard to cut away since it goes into the indent of the panel a bit.
Thanks
Thanks
