mobo
Diesel-man3000
Ok i bougt a dell e521 like a month ago and i also got a evga 7900gs and 2x1 gig sticks of mushkin 6400 ram.I wanted to make my system more upgradeble in the long run so i ordered this case http://www.newegg.com/Product/Produc...82E16811146025
I know i need a new mobo so thats why i am posting here,i am using the hd and cd drive from my current build,and i am prob going to buy the xclio 500 watt psu.
so i am going to post the boards i have looked at you guys tell me whats best or give your own suggestions i plan on buying this week,also i am using the 3800x2 windsor that came with my system looking to get a oc up to 2.4 at least.keep in mind this is my first partial build.Never have built one before. BOards are below
which board do you guys think would work best open to all suggestions
currently looking at the biostar 550,550se,t570sli,t560 a2+
Asus:m2n-e nforce 500 sli,m2n-e nforce 570 ultra,m2npv-vm 6150
also i don't really know anything about gigibyte boards i don't really know anything except reading some good reviews about the 550 series
Please edit links to show board manufacturer and model at least. I refuse to click on a bunch of links without having some idea what products they're going to.
so why did you buy the E521? lol... you basically replaced (or will replace) almost everything in it?
a stupid mistake i made,i just want you guys help on picking mobo so i can finish this and get on with life.I'm tired of people asking me that i made a big mistake thinking it was more upgradeble only 16 and was my first computer and first buying experience besides buying a 360.So can you guys just give your insight into what mobo i should get THX
Heh, so whats making you want to upgrade? The 3800+ X2 isn't bad at stock speeds. What are you doing thats making it seem slow? If its games, all you really need is a better GPU. What size monitor are you using?
My main point was, you're basically building a new computer. Why not just put the dell back together, sell it, then buy yourself a new core2duo system? It'll be much faster than the 3800+ X2. Its just food for thought.
Anyway... motherboards... I'd stay away from the Asus boards... just because I've had problems with them. Though, they say those problems are gone now... but they left a "bad taste" in my "mouth." The TForce 550's were popular with bundles, and they OC well. An AMD 690g based board is also a good option.
its alot harder than you think to sell a system,when most people think your selling a computer they would think it comes with the monitor when all i wanna sell at the moment is the tower which i paid 464 on and i am willing to part with it for 350-300 which i think is fair.I still think it would take to long to sell it plus i wanna just finish up with this.So could you point out the best am2 board under a 100 bucks
Well if you want a general idea of which mobo to get, you may want to check out the AMD subforum under the Motherboard forum here. Then again that forum has been a little bit quiet in the past few months due to a certain CPU launch. :)
Anyway, the TForce 550, like enginurd said, is a pretty popular board that OC'd quiet nicely: http://hardforum.com/showthread.php?t=1168208
The only problem I can think of with that board is that it isn't an AM2+ board like the TF560 A2+ is. Dunno how well the TF560 A2+ can OC but if my line of reasoning is right, the TF560 is an updated version of the TForce 550 for the AM2+ socket so it should be a pretty decent OC'er.
So if you're planning to upgrade to the new Phenom CPUs in a few months or even a year from now, the TF560 A2+ is your best bet for increased longevity of your system. However if you want a board thats well known for cheap OCing, then the TForce 550 will do you well.
Oh and next time you list a lot of motherboards, make sure you leave a space between the mobos, k? Too clumped up together.
I thought all am2 boards were compatible with the new processor,i coulda sworen in other threads that a guy said they just put the a2+ on the boards to get more attention and those arent the updated boards?
Yes, AM2+ CPUs are backwards compatible with AM2 socket mobos. But you just won't get all of the benefits of an AM2+ which, according to wikipedia, are:
Socket AM2+ will have some differences however that will be used in AM2+ chips, there are two main features in Socket AM2+ not in Socket AM2:
* HyperTransport 3.0 operating at up to 2 GHz
* Split power planes: one for the CPU cores, and the other for the Integrated Memory controller (IMC). This will improve power savings especially with integrated graphics if CPU cores in sleep mode but the IMC still active.
Doesn't look like much eh? So you really don't need the updated board if you don't want it.
i wanna buy now so which board 550se or the t560,considering i still have a ide hd i think cus i have a dell its ide i did see the long cable in the box which i think is ide strap so ya which board considering i order right now.
alright credit card charged.once i get back in town and pick up my next paycheck i should be able to finish build all i need is power supply now thinking about the xclio 500 watter
