Mobo Suggestion
brownkc
I'm looking to up upgrade the first system in my signature. I plan to go to an IB 3570K with a decent overclock without increasing voltage (hopefully 4.2-4.4 based on reports). I will need to pick up the chip and a mobo. I will reuse everything in the signature except switch out the TRUE heatsink with a Corsair H100. I already purchased RAM at the end of last year expecting the cost to shoot back up. It's 2 packs of 2x4GB GSkill Ripjaws X Series DDR3 1600 CL9.
Features I want in a mobo are the ability to run 2 video cards and 2 PCI Express cards at the same time. I do not need PCI slots. I want at least 2 SATA III connections, 2 USB 3.0 connections on back (preferably 4) and 1 internal header, an Intel NIC and the ability to run RAID 0 for my back up hard drive. I've been admiring the Asus Sabertooth Z77 but don't know if it is overkill for my needs. Asus boards seem to be the only ones that meet my wants above and I have a good track record with them.
Mostly gaming and browsing. I do limited photo editing and website design.
No budget but I generally buy the top mobo only to realize I don't use half of the features.
Austin, TX USA
Mobo but I am also open to any recommendations on the CPU. It seems like the 3570K is the sweet spot though.
Corsair 600T, Corsair 750tx, EVGA SC GTX 580, Crucial M4 256GB SSD, 2xWD 640GB AAKS (Raid 0), Samsung Lightscribe DVD burner x 2, Win7 64 Ultimate
6) Will you be overclocking?
Yes. Stable on stock voltage unless you would recommend a slight increase to maximize performance. I don't care to nitpick settings. I would rather just increase the multiplier, test and if successful leave it there.
2560x 1600, 30"
ASAP unless there is a reason to hold off a month or two.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
I want RAID 0 capability for my backup drives. I will be using a 256GB SSD for the primary. I would like the ability to add a second dual height video card but will still want 2 accessible PCI Express slots (x1/x4) for other cards. I would prefer 4 USB 3.0 connections on back plus an onboard header for the connection on the front of my case. I need at least 1 SATA III 6Gb/s connection for the SSD. I do have an external eSATA back up drive but don't use it that frequently (nice to have but not a deal killer). I would like to move to UEFI but I am comfortable with an old school BIOS. Having backup onboard video would be nice. I like to upgrade incrementally and have had a bad video card or two. I prefer Intel for the onboard NIC. I currently use an Intel NIC card for the best speeds on my gigabit home network.
I have a reuseable Windows 7 64 bit Ultimate license.
Is the Atheros NIC up to snuff? I found a move to an Intel NIC on both my HTPC and Main system made a noticeable improvement in speed when shuffling files around. The HTPC is a Gigabyte board and the Main PC is using an Asus board. It looks like they both used Marvel chips on onboard for GbE and I saw a 20-50% improvement by going to an Intel NIC.
