Mobo memory compatibility
kcar711
I just bought a motherboard for my new computer and the memory speed standard for the mobo is DDR2 667 but the memory I bought is DDR2 800. I was wondering if I might run into compatibility issues with the speed variation.
What motherboard did you buy? Usually, if you check the manufacturer website, it tells you. If not, contact the RAm manufacturer and tell them the board you bought and the ram you want to use, they will tell you if it will work out or not. GL :cool:
You should be fine. Most memory has multiple By SPD timings for multiple settings. Worst case scenario is your DDR2 800 memory runs at DDR2 667 speed. Possibly with tighter timings.
