beamer7296
- Nov 19, 2006
Okay, right now I am debating between an E6600 and a Pentium-D Processor 960. The E6600 FSB runs at 1066 Mhz and the 960 at 800 MHz.
Should the motherboard I get be able to support the same frequency as the FSB? I ask because I've heard that running your RAM/FSB at the same frequency is typically benficial (but not always necesarily the case with intel processors).
The GeForce 680i seems to be popular for the E6600. Would you reccomend anything else over it? What motherboard would you reccomend for the 960?
It seems hard to find any ram above 800 MHz, so regardless of which processor I choose, should I get a motherboard that supports 800 MHz?
Would the following setup of 1066 FSB, 800 MHz supported Ram Mobo, 800 MHz Ram be any more beneficial than 800 FSB, 800 MHz supported Ram Mobo, 800 MHz Ram? If so, why? Is it just going to be more overclockable?
Thanks in advance for your help guys!
