Mobo gone bad .... replacement opinions
lazarus0
so i have the K8n neo4 platinum sli mobo that has bit the dust
looking for replacement board opinions.
need:
pci-express
sli
stability
SATA
decent overclocker
suggestions please .......... or should i just stick with the same one?
thanks
inital list of possibles
LANPARTY UT nF4 SLI-D Socket 939 NVIDIA nForce4 SLI ATX AMD Motherboard - Retail
Price Unit Price: $128.99
ASUS A8N-SLI Premium Socket 939 NVIDIA nForce4 SLI ATX AMD Motherboard - Retail
Unit Price: $132.99
DFI LANPARTY UT nF4 SLI-DR Socket 939 NVIDIA nForce4 SLI ATX AMD Motherboard -
Total: $122.99
DFI LANPARTY nF4 SLI-DR Socket 939 NVIDIA nForce4 SLI ATX AMD Motherboard -
Unit Price: $134.99
ABIT AN8 32X Socket 939 NVIDIA nForce4 SLI X16 ATX AMD Motherboard - Retail
Total: $108.99
It really depends on your budget. Id reccomend the asus a8n 32sli deluxe but its 150.00 or so. The asus a8n sli premium is another great board for 125.00 or so.
The abit an8 32x is another good board for 109.00 from newegg rite now and a great deal.
Also if you were pleased with the msi isnt it still under warranty? if not and its cheap and you were happy with it get another then. But for my opinion as the best board Id get the asus a8n 32sli or the abit an8 32x.both are 16x16 sli boards and the abit is priced very affordable right now.....check it out.
thanks for the response
i guess they have stop making the msi n4 sli plat ... the price is still way up there.
what's the difference between the asus premium and the asus deluxe beside the addition Lan port?
I would go either DFI or the ASUS A8n Premium. Personally would go for the DFI Ultra D(think you can get it for about $100 now) A8n Premium cant recall but performance is on par with DFI. A8N32 DLX has the best performance out of the 3 and supports full dual 16X SLI
you may want to read this too: http://anandtech.com/mb/showdoc.aspx?i=2589
INFRNL
the main difference between the asus a8n sli deluxe and premium is the premium handles the dual/single vid cards in bios and on the deluxe it's a small card that gets flipped when you go sli.heatpipe on the premium for chipset cooling(no fan),other than that,they are almost identical.
actually, both premium and deluxe have heatpipe cooling and handle sli in BIOS. deluxe=16x SLI in both slots
mwave has the A8n32 sli deluxe for $142 bucks ....
thinking about that now
did Asus ever fix that resistor/reboot issue during large file transfers?
ok ...
the ASUS a8n32 sli deluxe for $142
or the
DFI LanParty UT NF4 SLI-DR Expert for $121
the asus runs a true x16 sli while the DFI runs x8 each
how much of a difference will that make?
which board is better?
the layout of the Asus blocks the other pci slots as well.
Assuming that might be an MSI board it has a 3 year warantee. You can do an RMA through their website. As you fill out the RMA form it will tell you if you are still under warantee.
Their typical turn around time is one week.
Luck
Luck
I would say that this is your best option. If you can handle not having your board for a while. Why spend $100 when you don't have to. MSI boards are 3 year warranties IIRC.
