Anyone hear anything about Intel desktop motherboards not supporting Server 2003 & 2008? A friend just sent me a link with the information. It's news to me
Also, I did check out the troubleshooting sticky, but I know most of those things already, but I don't get any power to anything so I can't try any of those.
... If your system doesn't POST...
This is basic troubleshooting if your system has never POSTed (as in, you just put it together); Though, it may be helpful to others whose system no longer POSTs...
If you have both the 20/24 pin main ATX connector plugged in, AND the 4-Pin (or 8-pin) ATX12V P4 CPU connector plugged in, then the board should boot fine (unless it requires more power connectors from the PSU). First, try clearing the CMOS w/ the proper jumper or button.
The next thing you could do is test the PSU. Jump start it (on the main atx connector, short the green wire with any black wire, using a paperclip), and see if it stays on. If not, then its probably a faulty PSU. If it works then you can proceed with the suggestions below. ***NOTE: The paperclip trick is a simple test for those that do not have PSU testers, multimeters, nor a spare PSU to test with. It is not a 100% conclusive test of the PSU.
How to test with a multimeter @ BFG
Setup everything outside of the case, with the mobo on top of its cardboard box. Plug in only the essentials: (this is also known as a barebone bench test)
- PSU (namely: main 20/24-pin ATX connector and 4-pin ATX12V P4 CPU Connector; The 4-pin should work in the 8-pin EPS12v plugs, too)
- CPU w/ HSF
- Single stick of ram
- Videocard if there is no onboard video (along with its molex or PCI-E power connector, if it has one)
- System speaker/buzzer (your board may have an on-board buzzer/speaker)
- Monitor & Keyboard
Reset/Clear the CMOS by following the instructions in your mobo manual. If you can, check to see that you have the latest BIOS udpate from the mobo manufacturer.
* Use a screwdriver if your board doesn't have an onboard power switch. Jump the two power switch leads to turn the power on (connect both pins for 1-2 seconds with something conductive).
If it won't POST, try different RAM slots. If it still won't post, pull out the ram (so no ram in the system) and listen for error beeps. If none, pull the vidcard and listen for error beeps. If none, re-seat the CPU and HSF, then try again. Report back with results if you're still having issues.
It looks like you made it this far... but yet you can't do the rest? What's stopping you?
... I'm not sure of the correct operation for this board. This light blinks when the PSU is flipped on. It does not stay on/off...
