Hi i am in the process of building a PC right now and will be ordering parts tonight.The mobo that i picked is a,
GA-MA770T UD3P
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128392
and the CPU is the newly released Phenom x2 555
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103846
I was wondering if i would need a BIOS update in order for the cpu to work with that mobo. And if so which update would i need? Would the f5 be okay. Also is it possible to unlock cores on the f5, since i've only heard you can do them on f2c.
GA-MA770T UD3P
