Space_Coyote
- Feb 2, 2007
Gaming, game development
$300 or so
McHenry, IL
Mobo, 2x8GB RAM, CPU cooler
Seasonic X650 PSU, Sapphire 7870 XT Boost, Samsung 830 128 GB SSD, 2TB HDD
6) Will you be overclocking?
Yes
2560x1440, 27"
Now
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Good on-board sound, USB 3.0, good overclocking
W7 64-bit
I already have an i7-4790K and Antec P280 case on the way. For the motherboard, I was thinking either the Asus Z97-A or Gigabyte Z97X-SLI. I want this to last 5 years or so, and I've read about some issues with the Z97X, so I'm thinking that the Asus is probably the way to go. The Hyper 212 Evo seems like a no-brainer for the cooler, so really the only thing I'm not confident in is the RAM.
There are so many different speeds, latency, timing etc, and I'm not sure what is best for overclocking. I'll probably stay stock for a while, since it's such a huge upgrade for me, and look the squeeze the most performance out of the 4790K as time goes on. My limited research leads me to believe that 1866 Mhz, latency 9, and 1.5v is the way to go? Are there any major difference between these to warrant the extra cash?
$300 or so
McHenry, IL
Yes
2560x1440, 27"
Now
W7 64-bit
