MOBO 4 e6600 + kensfield
se1zure
I am looking for a motherboard for my e6600, and am getting really stumped. I want a motherboard ofr the following:
-my e6600
-Upgradable to the core2quads (kentsfield)
-can take *at least* ddr-2 800 ram
-can take at least 8 gb of ram
-Sli would be *really* nice, but I hear that it is in every case a better option to buy a better end single card, than two lower end ones.
-Some of them say WiFi, does that mean they have a built in wifi card, or what? This would be sweet!
-Good FSB speed
-Good for overclocking my e6600 up to 3.4 ghz on stock cooling
My price range is about $90 - $150, here are some of the mobos I have been looking into:
ASUS p5w DH Delux - I hear this is the best, and the only way it's in my price range is through... open box :(. I have never bought an open box item, and am worried, Is it okay to buy an Open Box mobo?
http://www.newegg.com/Product/Product.asp?Item=N82E16813131025R
ASUS P5B Deluxe Socket T (LGA 775) Intel P965 - Not sure how this compares to the p5w...
http://www.newegg.com/Product/Product.asp?Item=N82E16813131045
GIGABYTE GA-965G-DS3 Socket T (LGA 775) Intel G965 Express - Discount w/ my new processor, not sure about board quality and how well it works though.
http://www.newegg.com/Product/Product.asp?Item=N82E16813128018
GIGABYTE GA-965P-S3 Socket T (LGA 775) Intel P965 Express - Definately in my budget :D. How is this mobo?
http://www.newegg.com/Product/Product.asp?Item=N82E16813128017
UNFORTUNATELY, none of these are SLI :(, but I think sli is a little overrated. Can you name any bette rchoices for my slim budget, or is the open box asus my best bet?
I would look at the newer P5B-E board rather than the others listed. I have a P5W and it's nice, but with open box, you don't always get all the accessories. Personally, I would get that over the DS3, but I've used the DS3 also, and it's a great board too. If you shop around, the P5B-E is around $160...the P5W is around $220. The S3 board is the same as the DS3 but without the solid state capacitors. For the price, it's a great OCing board. I don't think you'd have a problem getting to 3.4Ghz with any of those boards as long as your chip can handle it.
Yes, Wifi means built in Wifi card. Mine doesn't always work properly though :(. I don't even use the feature personally.
which is better, the p5b-e or the p5w? I really don't understand too much about motherboards, but I really think that p5w is NICe with the wifi, and remote.
I'm not sure you'd get the wifi/remote if you went open box. You might and you might now. IMHO, it's not worth taking a risk. I'd probably just spend $160 and get the P5B-E. $10 over your price range, but the best board in that category IMHO.
@ MrWizard6600
is that worth the extra money? Will I notice a huge speed boost? What features does the 680i have over the p5w?
If need be, I'll get the $30 cheaper ram, and stick with my 7600gt instead of the GS i was going to get , so i can get this faster motherboard, (but is it really worth it, also, can't the processor handle a certain FSB speed, and that mobo goes above that...)
You won't notice anything in the 680i over the P5W (or P5B for that matter) unless you're running SLI. You'll definitely be better off getting a "cheaper" motherboard and a better graphics card.
