Mixing SATA and IDE devices ?
Grackdor
Hi all,
Just starting to put together ideas for a new build. Am planning to go with a SSD for O/S and Apps drive. But, I was also hoping to save a few $$ by re-using the DVD drive and a HDD from my old system. The thing is , they're both IDE, not SATA.
I am reading that when installing the SSD, I should go into the BIOS and make sure it's set to AHCI, rather than IDE. But, will doing this have ANY bad side effects on either of my old IDE devices? Is it even a good idea to try to mix the two types ? I am mostly concerned about system stability/reliability.
Any advice or personal experiences with something like this would be most appreciated.
shouldn't be any side effects.
Posted via [H] Mobile Device
