Missing thermistor from Fortron PSU
larrymoencurly
I have some 350W Fortron-Sparkle model FSP-350BU PSUs with empty spots where a thermistor and fixed resistor would normally be connected in series, and I'd like to know their purpose. I think that they connect this way:
Capacitor C10 and pin 18 are on the small vertical circuit board (beneath the removed fan controller board in the photo below) housing the Fairchild KA3511DS PSU controller chip, and according to the URL=http://www.ortodoxism.ro/datasheets/fairchild/KA3511.pdf]Data sheet for KA3511DS[/URL], pin 18 is the Extra Protection (EP) input, which is supposed to shut down the PSU if its voltage goes high. In other words, this seems to rule out the thermistor being used as a overheat sensor because the pin 18 is low anyway in normal operation.
Here are where the missing resistor and thermistor are located (circled in red):
Given the diagram, and the thermistor's proximity to the secondary heatsink, it's gotta be overtemp protection - it's the only thing I can think of anyway. The thermistor (PTC type anyway) should allow voltage at pin 18 to increase as it heats up based on that schematic and the setting of the pot. With the thermistor absent, it seems logical to me the pot is set just below the value pin 18 requires to trip. Otherwise, in normal operation the thermistor would bleed off some power to ground (and less as it heats up and increases in resistance).
