Missing component Gigabyte Aorus 1080 Xtreme
sistom
Hello, I am posting to get some insight on a possible replacement component for my GTX 1080.
There was a component knocked off of the PCB, and I need help to identify it to try to search for a replacement part. I will attach a photo of the board with the missing piece.
Thank you
See attached.
Looks like a ceramic capacitor. The exact capacitance would be difficult to determine without getting your hands on the schematic or desoldering one from a good card and measuring it, but it's likely in the 10 nF ballpark.
Depending on which circuit on the card it's a part of, there's a pretty good chance that the card will still work without it.
Can you post a wider photo showing where on the card this is located?
