Wolfdale75
- Jun 17, 2010
Hi Guys,
Can anyone offer either factual info or opinions on the following? All constructive replies very gratefully received!
Thanks a lot.
1) Why does the (superior) Core i7 950 cost less than $275 but an Intel Core 2 Quad Q9650 at cost at least $330?
2) Where is the DNS server located does my router or my ISP provide it?
3) Should I max out my Socket 775 setup (add: Core 2 Quad Q9650, more DDR2 RAM, SSD) and wait until the next gen, or invest in i7 now? I do office work and some light gaming.
4) Are PCIe-based SSDs going to be the way forward?
5) Is it possible to run a USB 2.0 device as USB 3.0?
6) Can you get additional laptop video memory in ExpressCard form? Is it worth investing in?
7) At what speed does the PCIe bus run?
8) What's the difference between a patch and a hotfix?
9) Why is there still no PnP cable to directly connect 2 PCs? USB has been around since 1994...
10) Why can't we buy RAM made from cache memory?
11) Is RAM faster to read than flash memory?
12) Why not make RAM non-volatile so it stores our most recently used, or most used, data and apps after the power is unplugged? No more RAM refreshing!
13) Is an SSD the single most noticeable performance upgrade you can make? I.e. not CPU, not RAM etc.
