Mining with RTX 3060
Gekk0r
Hello to everyone,
What motherboard do you suggest to start mining with 4 ASUS RTX 3060 TUF/STRIX?
I already have an i5 6400T and G3930 or i7 4770k (xD) that I would like to use again...
Thank you in advance :)
Additional note:
I will extend my rig at least with 2 more GPU.
I failed 3 times to build my rig with the ASRock H110 Pro. All the times problems linked to no boot, no beeps and no signal.
Tested with the following new brand hardware:
i5 6400T and G3930 (perfect cpu pins bent)
DDR4 Corsair 2133 2133 CMV8GX4M1A2133C15
Two different modular PSU (CoolMaster 850W and Corsair 1000W)
Thank you in advance!
Archaea
If you had three H110 boards seem faulty and you bought them all new the problem is unlikely to be the board.
There is a motherboard mining thread in the crypto forum already.
The H110 is a good board.
The problem with any crypto mining motherboard recommendation right now is they are priced to the moon. I use an Asus B250 mining expert, but it’s crazy expensive right now. I just bought an old supermicro dual Xeon 1366 board off eBay with RAM and processors for dirt cheap. I’ll be expanding to that old platform just because it’ll run 5 or 6 cards and is unreasonably cheap.
https://hardforum.com/threads/new-mb-for-multi-gpu-mining.2006477/
Gekk0r
Exactly! It's a shame...
Thank you very much for the answer :)
