Mostly web, but light gaming & video work
2-3 hundread for this stage perferably, but not set in stone
3) Where do you live?
Idaho - No access to any B&M with decent prices. & I Will pay more at newegg then deal with anyone else.
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
CPU, Mainboard, Ram??
RocketFish Full Tower, Corsair hx520, GeForce 8800GT (xfx with zalman), Seagate 320gb 7200.10, 8 Gb OCZ PC 1066 DDR2 (4x times 2 Gb), Lite-On Optical
6) Will you be overclocking?
Negative
Haans G 281D 28" LCD @ 1920x1200
This week or next (maybe tonight)
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
PciE 16x & atleast 2 SATA & GbE ethernet
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
Yes, Vista Home Premium 64 Bit (used when gaming, but primarily use linux for day to day.
Basically I am torn between going with a 775 or a 1156 setup (unfortunately AMD inst an option due to no avail motherboards with a real PCIE).
I Know better performance of the 1156, But what I have now is overkill as it is so its not the end of the world. The rest of my curent parts will be used for now, But moved over to replacements to work with MicroITX Form Factor as needed. Video will probably end up as a 5770 in the next few months because I dig eyefinity (assuming it supports it)..
Edit: That or I just buy a SSD instead since it will all get replaced anyhow..
Negative
