Mini PCIe on a Desktop?
JOSHSKORN
I was looking at this item on Newegg and was wondering if it's possible to make it work on a Desktop PC. I know it's meant for a laptop. The reviews of the item look good which is why I'm considering purchasing it.
Basically I'm looking for a wireless solution for my computer with a transfer rate of up to 450 Mbps (or whatever is the current highest). I don't see any internal card for a Desktop as of yet.
What's the difference between PCI-e and mini PCI-e? Are the ports different sizes? If so, is there an adapter that will do the trick? I could not find anything and figured someone here may know something. I realize mini PCI-e is meant for a laptop.
Is there another, similar device for the Desktop?
You'll also need a router that matches that speed if you want to actually use that speed.
