MINI ITX boards?
The_Bob
I am looking to build a Mini ITX pc and I'm looking of a good mobo. I read something a while back about a dual cpu Via board and if thats out that would be sweet. I'm looking at via right now because I want a fanless pc but I'm up for Ideas.
You will get much better performance if you went to a Pentium M based solution but that will likely be alot more expensive then a via C3 product.
The dual C3 board much like the nano-itx board is no where to be found even though via has listed it on the website for like 6 months.
If you want a via system I would recomend what board has the features you like but make sure you get at least a 1 ghz nehemiam core the older samuel and ezra cores are a lot slower.
There's no such thing as mini ITX for P4. Mini ITX is the Via EPIA.
I think the smallest you can go with a P4 (or an Athlon for that matter) is the MicroATX, which is significantly larger than a Mini ITX.
Last I heard was that VIA stopped making them. Notice at Mini-box it is out of stock and at Mini-Itx.com it has been "long lead time" for a long time.
And I didn't think the Commell boards were actually Mini ITX or available to anyone but system builders. I have one in a MP3 server/player I have from Request Multimedia.
False. Mini-ITX is simply another formfactor, like ATX. Mini-ITX is a small version of the ITX formfactor.
