Migrating from one drive to another
jnick
Hey all,
For my GFs birthday, I built her her first machine. At the time, I had used my old 74GB raptor, thinking it should be fine...boy was I wrong. She is running out of space, FAST.
I have a WD 640GB black that I'd like to replace it with. However, I do not want her to lose anything and am looking to create an image from the raptor, then shoot it down to the 640GB drive, with all 640GB being accessible in one partition.
What would be the easiest/safest way to accomplish this? Something like Acronis? Or something else?
Thanks!
My Acronis 11 didn't work when I tried copying my SSD to another with Windows 7
You must have done something wrong.
I've done that many times.
AAR jnick, you really want to clone the drive and expand the clone to use all the avaliable space on the new drive.
WD's free version of Acronis does work well but it just lacks many options.
Acronis also has free trials with all the options working.
If you don't want her to lose anything you should consider backups.
For your simple clone, even free tools (like driveimagexml) should work fine.
